Optimal control of linear complementarity systems
Contrôle optimal des systèmes de complémentarité linéaire
In this paper, we give some results concerning the quadratic optimal control of linear complementarity systems. We derive first order conditions for this system, that we manage to express as a Mixed Linear Complementarity System. We then use this result to build numerical schemes, which are expressed as Mathematical Problems with Equilibrium Constraints.
