Random Moments for Sketched Mixture Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2017
We present a method to solve large-scale mixture learning tasks from a sketch of the data, formed by random generalized empirical moments. We give empirical and theoretical results on k-means and Gaussian Mixture Model estimation problems.
spars_abstract.pdf (345.32 Ko) Télécharger le fichier
hal-01494045 , version 1 (22-03-2017)
  • HAL Id : hal-01494045 , version 1
Nicolas Keriven, Rémi Gribonval, Gilles Blanchard, Yann Traonmilin. Random Moments for Sketched Mixture Learning. SPARS2017 - Signal Processing with Adaptive Sparse Structured Representations workshop, Jun 2017, Lisbon, Portugal. ⟨hal-01494045⟩
583 Consultations
287 Téléchargements
