A parallel and memory efficient algorithm for constructing the contour tree, 2015 IEEE Pacific Visualization Symposium (PacificVis) (2015), pp.271-278 ,
The h, p and h-p version of the finite element method: Basis theory and applications, Adv. Eng. Softw, vol.15, issue.1, pp.3-4, 1992. ,
Interactive exploration and analysis of large-scale simulations using topology-based data segmentation, IEEE Transactions on Visualization and Computer Graphics, vol.17, issue.9 2, pp.1307-1324, 2011. ,
Simple and optimal output-sensitive construction of contour trees using monotone paths, Computational Geometry, vol.30, issue.2, pp.165-195, 2005. ,
Introduction to Algorithms, 2009. ,
Nektar++: An open-source spectral/ element framework, Computer Physics Communications, vol.192, issue.1, pp.205-219, 2015. ,
Computing contour trees in all dimensions, Computational Geometry, vol.24, issue.2, pp.75-94, 2003. ,
Computing Contour Trees for 2D Piecewise Polynomial Functions Nonlinear particle tracking for high-order elements, Journal of Computational Physics, vol.172, issue.1 1, pp.356-386, 2001. ,
Flexible isosurfaces: Simplifying and displaying scalar topology using the contour tree, Comput. Geom. Theory Appl, vol.43, issue.2, pp.42-58, 2010. ,
Certified computation of planar morse-smale complexes, Proceedings of the 2012 symposuim on Computational Geometry, SoCG '12, pp.3-40, 2017. ,
DOI : 10.1145/2261250.2261288
Parallel peak pruning for scalable smp contour tree computation, 6th IEEE Symposium on Large Data Analysis and Visualization, 2016. ,
Trekking in the Alps without freezing or getting tired, Algorithmica, vol.18, issue.3, pp.306-323, 1997. ,
DOI : 10.1007/3-540-57273-2_49
Output-sensitive construction of reeb graphs, IEEE Transactions on Visualization and Computer Graphics, vol.18, issue.1 2, pp.146-159, 2012. ,
An exploration framework to identify and track movement of cloud systems, IEEE Transactions on Visualization and Computer Graphics, vol.19, issue.2, pp.2896-2905, 2013. ,
Topology-guided tessellation of quadratic elements A preliminary version of this paper, Proceedings of the 17th International Symposium on Algorithms and Computation, pp.195-211, 2006. ,
Volume data mining using 3d field topology analysis, IEEE Comput. Graph. Appl, vol.20, issue.5 2, pp.46-51, 2000. ,
Contour forests: Fast multi-threaded augmented contour trees, 6th IEEE Symposium on Large Data Analysis and Visualization, 2016. ,
Rendering higher order finite element surfaces in hardware, Proceedings of the 1st International Conference on Computer Graphics and Interactive Techniques in Australasia and South East Asia GRAPHITE'03, pp.211-212, 2003. ,
In-situ feature extraction of large scale combustion simulations using segmented merge trees, SC14: International Conference for High Performance Computing, Networking, Storage and Analysis, pp.1020-1031, 2014. ,
A hybrid parallel algorithm for computing and tracking level set topology, High Performance Computing (HiPC), 2012 19th International Conference on, pp.1-10, 2012. ,
Ray-tracing polymorphic multidomain spectral/hp elements for isosurface rendering Elvis: A system for the accurate and interactive visualization of high-order finite element solutions, IEEE Transactions on Visualization and Computer Graphics IEEE Transactions on Visualization and Computer Graphics, vol.12, issue.18 1, pp.114-125, 2006. ,
Efficient Parallel Vectors Feature Extraction from Higher-Order Data, Computer Graphics Forum, vol.16, issue.6, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01924.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.683.446
Efficient visualization of high-order finite elements, International Journal for Numerical Methods in Engineering, vol.69, issue.4 1, pp.750-771, 2007. ,
Methods and framework for visualizing higher-order finite elements, IEEE Transactions on Visualization and Computer Graphics, vol.12, issue.4 1, pp.446-460, 2006. ,
Concepts -Numerical C++ Library for partial differential equations ,
Extended Branch Decomposition Graphs: Structural Comparison of Scalar Data, Computer Graphics Forum, issue.2, 2014. ,
Symmetry in scalar field topology, IEEE Transactions on Visualization and Computer Graphics, vol.17, issue.12 2, pp.2035-2044, 2011. ,
Topological volume skeletonization and its application to transfer function design, Graphical Models, vol.66, issue.1 2, pp.24-49, 2004. ,
Construction of contour trees in 3d in o(n log n) steps, Proceedings of the Fourteenth Annual Symposium on Computational Geometry SCG '98, ACM, pp.68-75, 1998. ,
Contour trees and small seed sets for isosurface traversal, Proceedings of the thirteenth annual symposium on Computational geometry , SCG '97, pp.212-220, 1997. ,
DOI : 10.1145/262839.269238
Feature tracking using reeb graphs, Topological Methods in Data Analysis and Visualization: Theory, Algorithms, and Applications, pp.241-253, 2011. ,
Contouring curved quadratic elements, VisSym, 2003. ,
Topology-controlled volume rendering, IEEE Transactions on Visualization and Computer Graphics, vol.13, issue.2 2, pp.330-341, 2007. ,
