Scaling the Scattering Transform: Deep Hybrid Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We use the scattering network as a generic and fixed ini-tialization of the first layers of a supervised hybrid deep network. We show that early layers do not necessarily need to be learned, providing the best results to-date with pre-defined representations while being competitive with Deep CNNs. Using a shallow cascade of 1 × 1 convo-lutions, which encodes scattering coefficients that correspond to spatial windows of very small sizes, permits to obtain AlexNet accuracy on the imagenet ILSVRC2012. We demonstrate that this local encoding explicitly learns in-variance w.r.t. rotations. Combining scattering networks with a modern ResNet, we achieve a single-crop top 5 error of 11.4% on imagenet ILSVRC2012, comparable to the Resnet-18 architecture, while utilizing only 10 layers. We also find that hybrid architectures can yield excellent performance in the small sample regime, exceeding their end-to-end counterparts, through their ability to incorporate geometrical priors. We demonstrate this on subsets of the CIFAR-10 dataset and by setting a new state-of-the-art on the STL-10 dataset.
iccv2017_conference.pdf (218.31 Ko) Télécharger le fichier
bullsit-eps-converted-to.pdf (9.04 Ko) Télécharger le fichier
little_wood-eps-converted-to.pdf (12.41 Ko) Télécharger le fichier
little_wood_1d-eps-converted-to.pdf (12.81 Ko) Télécharger le fichier
hal-01495734 , version 1 (27-03-2017)
hal-01495734 , version 2 (03-04-2017)
Licence Ouverte - etalab
Edouard Oyallon, Eugene Belilovsky, Sergey Zagoruyko. Scaling the Scattering Transform: Deep Hybrid Networks. 2017. ⟨hal-01495734v1⟩
873 Consultations
941 Téléchargements
