The Data Exploration System for Image Processing Based on Server-Side Operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper the possibilities for construction of an ad hoc search system to examine large-sized raster image data sets, e.g. rock images or medical images, for analysis of its characteristic parameters are presented. A new solution for image exploration based on any attributes extracted with computer image analysis by using extensions for server-side operations is proposed.
978-3-642-40925-7_17_Chapter.pdf (2.23 Mo) Télécharger le fichier
hal-01496063 , version 1 (27-03-2017)
Paternité
Magdalena Ładniak, Adam Piórkowski, Mariusz Młynarczuk. The Data Exploration System for Image Processing Based on Server-Side Operations. 12th International Conference on Information Systems and Industrial Management (CISIM), Sep 2013, Krakow, Poland. pp.168-176, ⟨10.1007/978-3-642-40925-7_17⟩. ⟨hal-01496063⟩
92 Consultations
131 Téléchargements
