<tex>$rm K$</tex>-SVD: An Algorithm for Designing Overcomplete Dictionaries for Sparse Representation, IEEE Transactions on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
DOI : 10.1109/TSP.2006.881199
Mathematical problems in image processing, 2002. ,
Chromaticity Denoising using Solution to the Skorokhod Problem, Image Processing Based on Partial Differential Equations. Mathematics and Visualization , Part II, pp.149-61, 2007. ,
DOI : 10.1007/978-3-540-33267-1_9
Modified diffusion to Image Denoising, Adv. Soft Comp, vol.45, pp.92-99, 2007. ,
DOI : 10.1007/978-3-540-75175-5_12
Smoothing, Enhancing Filters in Terms of Backward Stochastic Differential Equations, LNCS, vol.6374, pp.233-240, 2010. ,
DOI : 10.1007/978-3-642-15910-7_26
Euler???s Approximations to Image Reconstruction, LNCS, vol.7594, pp.30-37, 2012. ,
DOI : 10.1007/978-3-642-33564-8_4
Application of Backward Stochastic Differential Equations to Reconstruction of Vector-Valued Images, LNCS, vol.7594, pp.38-47, 2012. ,
DOI : 10.1007/978-3-642-33564-8_5
A Non-Local Algorithm for Image Denoising, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), pp.60-65, 2005. ,
DOI : 10.1109/CVPR.2005.38
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.9157
A Review of Image Denoising Algorithms, with a New One, Multiscale Modeling & Simulation, vol.4, issue.2, pp.490-530, 2006. ,
DOI : 10.1137/040616024
URL : https://hal.archives-ouvertes.fr/hal-00271141
Non-Local Means Denoising, Image Processing On Line, vol.1, 2011. ,
DOI : 10.5201/ipol.2011.bcm_nlm
URL : http://doi.org/10.5201/ipol.2011.bcm_nlm
Image Selective Smoothing and Edge Detection by Nonlinear Diffusion, SIAM Journal on Numerical Analysis, vol.29, issue.1, pp.182-193, 1992. ,
DOI : 10.1137/0729012
Image Processing and Analysis ? Variational, PDE, wavelet, and stochastic methods, SIAM, 2005. ,
DOI : 10.1137/1.9780898717877
Image Denoising by Sparse 3-D Transform-Domain Collaborative Filtering, IEEE Transactions on Image Processing, vol.16, issue.8, pp.2080-2095, 2007. ,
DOI : 10.1109/TIP.2007.901238
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.5398
BM3D Frames and Variational Image Deblurring, IEEE Transactions on Image Processing, vol.21, issue.4, pp.1715-1728, 2012. ,
DOI : 10.1109/TIP.2011.2176954
URL : http://arxiv.org/abs/1106.6180
Ideal spatial adaptation by wavelet shrinkage, Biometrika, vol.81, issue.3, pp.425-455, 1994. ,
DOI : 10.1093/biomet/81.3.425
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5288
Stochastic relaxation, gibbs distributions and the bayesian restoration of images, IEEE Pat. Anal. Mach. Intell, vol.6, pp.721-741, 1984. ,
Stochastic Motion and the Level Set Method in Computer Vision: Stochastic Active Contours, International Journal of Computer Vision, vol.21, issue.2, pp.7-25, 2006. ,
DOI : 10.1007/s11263-006-6849-5
Decoupled inverse and denoising for image deblurring: Variational BM3D-frame technique, 2011 18th IEEE International Conference on Image Processing, 2011. ,
DOI : 10.1109/ICIP.2011.6116455
Implementation of the Non-local Bayes image denoising, Image Processing on Line, 2011. ,
Sparse Representation for Color Image Restoration, IEEE Transactions on Image Processing, vol.17, issue.1, pp.53-69, 2008. ,
DOI : 10.1109/TIP.2007.911828
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.102.6724
Scale-space and edge detection using anisotropic diffusion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.7, pp.629-639, 1990. ,
DOI : 10.1109/34.56205
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.2553
Bayesian-Based Iterative Method of Image Restoration*, Journal of the Optical Society of America, vol.62, issue.1, pp.55-59, 1972. ,
DOI : 10.1364/JOSA.62.000055
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, pp.259-268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
Euler's approximations of solutions of SDEs with reflecting boundary, Stochastic Processes and their Applications, vol.94, issue.2, pp.317-337, 2001. ,
DOI : 10.1016/S0304-4149(01)00087-4
Stochastic Differential Equations with Reflecting Boundary Condition in Convex Regions, Hiroshima Math. J, vol.9, issue.1, pp.163-177, 1979. ,
DOI : 10.1142/9789812778550_0013
Stochastic differential equations and geometric flows, IEEE Transactions on Image Processing, vol.11, issue.12, pp.1405-1416, 2002. ,
DOI : 10.1109/TIP.2002.804568
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.5209
Algorithms for stochastic approximations of curvature flows, Proceedings 2003 International Conference on Image Processing (Cat. No.03CH37429), pp.2-3, 2003. ,
DOI : 10.1109/ICIP.2003.1246764
Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, pp.600-612, 2004. ,
DOI : 10.1109/TIP.2003.819861
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.2477
Theoretical Foundations of Anisotropic Diffusion in Image Processing, Computing Suppement, vol.11, pp.221-236, 1996. ,
DOI : 10.1007/978-3-7091-6586-7_13
Coherence-Enhancing Diffusion Filtering, International Journal of Computer Vision, vol.31, issue.2/3, pp.111-127, 1999. ,
DOI : 10.1023/A:1008009714131
<title>Local adaptive image restoration and enhancement with the use of DFT and DCT in a running window</title>, Wavelet Applications in Signal and Image Processing IV, pp.2-13, 1996. ,
DOI : 10.1117/12.255218
