Solving Steel Alloying Using Differential Evolution and SOMA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michal Holiš
  • Fonction : Auteur
  • PersonId : 1004689
Lenka Skanderová
  • Fonction : Auteur
  • PersonId : 1004690
Martin Placěk
  • Fonction : Auteur
  • PersonId : 1004691
Jiří Dvorský
  • Fonction : Auteur
  • PersonId : 994861
Ivan Zelinka
  • Fonction : Auteur
  • PersonId : 984213
This paper proposes method for solving steel alloying problem using evolution algorithms SOMA and differential evolution. Both algorithms belong to the family of the evolution algorithms but the main ideas of these algorithms are different. In differential evolution new offspring is created during the evolution, the individuals are crossed and mutated, while in SOMA the individuals move in the space of the possible solutions and the mutation is replaced by perturbation. The main goal of this paper is to discover how much these algorithms are usable and suitable to solve the problem of steel alloying.
978-3-642-40925-7_42_Chapter.pdf (382.85 Ko) Télécharger le fichier
hal-01496091 , version 1 (27-03-2017)
Paternité
Michal Holiš, Lenka Skanderová, Martin Placěk, Jiří Dvorský, Ivan Zelinka. Solving Steel Alloying Using Differential Evolution and SOMA. 12th International Conference on Information Systems and Industrial Management (CISIM), Sep 2013, Krakow, Poland. pp.453-464, ⟨10.1007/978-3-642-40925-7_42⟩. ⟨hal-01496091⟩
445 Consultations
58 Téléchargements
