Biomedical Distributed Signal Processing and Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper deal about the electrophysiology distributed data processing and analysis. The aim of the work was the distance computer environment for biomedical data processing services with effective data visualizing. The system combine end user interactive interaction with biomedical data was realized with the use of rapid calculating by FPGA technology. Combining of these technologies allows a vide range spectrum of users to quick access to proceed biomedical data. This article involved the possible topological proposal and implementation of that biomedical distributed signal processing system.
978-3-642-40925-7_9_Chapter.pdf (540.68 Ko) Télécharger le fichier
hal-01496102 , version 1 (27-03-2017)
Paternité
Marek Penhaker, Vladimir Kasik, Vaclav Snasel. Biomedical Distributed Signal Processing and Analysis. 12th International Conference on Information Systems and Industrial Management (CISIM), Sep 2013, Krakow, Poland. pp.88-95, ⟨10.1007/978-3-642-40925-7_9⟩. ⟨hal-01496102⟩
104 Consultations
313 Téléchargements
