Multiorgan Motion Tracking in Dynamic Magnetic Resonance Imaging for Evaluation of Pelvic System Mobility and Shear Strain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Strain Année : 2017
Female pelvic disorders have a large social impact, the diagnosis of which relies on a key indication: pelvic mobility. The normal mobility is present in a healthy patient, meanwhile the hypermobility can be a sign of female pelvic prolapse and the hypomobility for endometriosis. The evaluation of pelvic mobility is based on medical image analysis. However, the latter does not provide precise values of these indicators directly. Moreover, suspension devices play an important role in pelvic organ function, but can hardly be observed on medical images. Our objective is to propose an image-based analysis tool for the quantitative evaluation of pelvic mobility and the shear strain which has an impact on suspension devices. Hence, this paper introduces a such tool based on an e cient and semi-automatic motion tracking of multiple pelvic organs: the bladder, vagina and rectum presented in dynamic magnetic resonance imaging sequences. The method was validated on prototypical images and applied to di↵erent mobility cases. The computed displacement and shear strain fields provide important information on the quality of suspension devices between organs for a fine diagnosis in the clinical context, for example the early diagnosis of female pelvic prolapse and the localization of possible lesion areas before surgery. Meanwhile, the predicted mobility can be used to compare with the finite element model for numerical simulation.
Multiorgan Motion Tracking in Dynamic MRI (2017).pdf (16.39 Mo) Télécharger le fichier
hal-01496177 , version 2 (13-02-2017)
hal-01496177 , version 1 (27-03-2017)
Zhifan Jiang, Jean-François Witz, Pauline Lecomte-Grosbras, Jeremie Dequidt, Stéphane Cotin, et al.. Multiorgan Motion Tracking in Dynamic Magnetic Resonance Imaging for Evaluation of Pelvic System Mobility and Shear Strain. Strain, 2017, 53 (2), ⟨10.1111/str.12224⟩. ⟨hal-01496177v2⟩
732 Consultations
259 Téléchargements
