Modeling and Quantifying the Survivability of Telecommunication Network Systems under Fault Propagation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lang Xie
  • Fonction : Auteur
  • PersonId : 1004789
Poul E. Heegaard
  • Fonction : Auteur
  • PersonId : 1004748
Yuming Jiang
  • Fonction : Auteur
  • PersonId : 1004790
This paper presents a generic state transition model to quantify the survivability attributes of a telecommunication network under fault propagation. This model provides a framework to characterize the network performance during the transient period that starts after the fault occurrence, in the subsequent fault propagation, and until the network fully recovers. Two distinct models are presented for physical fault and transient fault, respectively. Based on the models, the survivability quantification analysis is carried out for the system’s transient behavior leading to measures like transient connectivity. Numerical results indicate that the proposed modeling and analysis approaches perform well in both cases. The results not only are helpful in estimating quantitatively the survivability of a network (design) but also provide insights on choosing among different survivable strategies.
978-3-642-40552-5_3_Chapter.pdf (275.13 Ko) Télécharger le fichier
hal-01497034 , version 1 (28-03-2017)
Paternité
Lang Xie, Poul E. Heegaard, Yuming Jiang. Modeling and Quantifying the Survivability of Telecommunication Network Systems under Fault Propagation. 19th Open European Summer School (EUNICE), Aug 2013, Chemnitz, Germany. pp.25-36, ⟨10.1007/978-3-642-40552-5_3⟩. ⟨hal-01497034⟩
66 Consultations
121 Téléchargements
