Novel Modalities for Bimanual Scrolling on Tablet Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ross Mclachlan
  • Fonction : Auteur
  • PersonId : 1004889
Stephen A. Brewster
  • Fonction : Auteur
  • PersonId : 920981
This paper presents two studies investigating the use of novel modalities for bimanual vertical scrolling on tablet devices. Several bimanual interaction techniques are presented, using a combination of physical dial, touch and pressure input, which split the control of scrolling speed and scrolling direction across two hands. The new interaction techniques are compared to equivalent unimanual techniques in a controlled linear targeting task. The results suggest that participants can select targets significantly faster and with a lower subjective workload using the bimanual techniques.
978-3-642-40483-2_16_Chapter.pdf (3.4 Mo) Télécharger le fichier
hal-01497438 , version 1 (28-03-2017)
Paternité
Ross Mclachlan, Stephen A. Brewster. Novel Modalities for Bimanual Scrolling on Tablet Devices. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.229-246, ⟨10.1007/978-3-642-40483-2_16⟩. ⟨hal-01497438⟩
31 Consultations
102 Téléchargements
