O-snap: Optimization-based snapping for modeling architecture, ACM Transactions on Graphics, vol.32, issue.6, pp.1-6, 2013. ,
A graph-based approach to symmetry detection, Symposium on Volume and Point-Based Graphics, Eurographics Association, pp.1-8, 2008. ,
3d spatial relationships model: a useful concept for 3d cadastre? Computers, Environment and Urban Systems 27, pp.411-425, 2003. ,
Piecewise planar and compact floorplan reconstruction from images, 2014. ,
Tricos: A tri-level class-discriminative co-segmentation method for image classification, European Conference on Computer Vision, 2012. ,
A small set of formal topological relationships suitable for enduser interaction, Advances in Spatial Databases, pp.277-295, 1993. ,
Efficient graph-based image segmentation, Int. J. Comput. Vision, vol.59, issue.2, pp.167-181, 2004. ,
Object detection with discriminatively trained part-based models. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.32, issue.9, pp.1627-1645, 2010. ,
2012. 3d object detection and viewpoint estimation with a deformable 3d cuboid model, pp.620-628 ,
Characterizing structural relationships in scenes using graph kernels, ACM SIGGRAPH 2011 Papers, pp.1-3412, 2011. ,
Real-time plane-sweeping stereo with multiple sweeping directions, Computer Vision and Pattern Recognition CVPR '07. IEEE Conference on, pp.1-8, 2007. ,
Patchmatchgraph: Building a graph of dense patch correspondences for label transfer, ECCV (5), pp.439-452, 2012. ,
Region-based segmentation and object detection, Advances in Neural Information Processing Systems, 2009. ,
3d object recognition in cluttered scenes with local surface features: A survey, pp.1-1, 2014. ,
Blocks world revisited: Image understanding using qualitative geometry and mechanics, 2010. ,
Thinking inside the box: Using appearance models and context based on room geometry, Proceedings of the 11th European Conference on Computer Vision: Part VI, pp.224-237, 2010. ,
Knowledge base approach for 3d objects detection in point clouds using 3d processing and specialists knowledge, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00778694
Putting objects in perspective, International Journal of Computer Vision, vol.80, issue.1, pp.3-15, 2008. ,
Bag-offeature-graphs: A new paradigm for non-rigid shape retrieval, Pattern Recognition (ICPR), 2012 21st International Conference on, pp.1513-1516, 2012. ,
Joint-shape segmentation with linear programming, ACM Transactions on Graphics, vol.30, issue.125, pp.1-12511, 2011. ,
Fine-grained semisupervised labeling of large shape collections, ACM Transactions on Graphics, vol.32, issue.190, pp.1-19010, 2013. ,
Qualitative organization of collections of shapes via quartet analysis, ACM Trans. Graph, vol.32, issue.71, pp.41-7110, 2013. ,
3d-based reasoning with blocks, support, and stability, pp.1-8, 2013. ,
Hallucinated humans as the hidden context for labeling 3d scenes, Computer Vision and Pattern Recognition (CVPR), 2013 IEEE Conference on, pp.2993-3000, 2013. ,
Relating things and stuff by high-order potential modeling, ECCV'12 Workshop on Higher-Order Models and Global Constraints in Computer Vision, 2012. ,
Acquiring 3d indoor environments with variability and repetition, ACM Transactions on Graphics, vol.6, pp.31-138, 2012. ,
Shape2pose: Human-centric shape analysis, Proc. of SIGGRAPH 2014, 2014. ,
Efficiently selecting regions for scene understanding, CVPR, pp.3217-3224, 2010. ,
Surface reconstruction through point set structuring, Proc. of Eurographics, 2013. ,
Geometry and context for semantic correspondence and functionality recognition in manmade 3d shapes, ACM Transactions on Graphics, 2013. ,
Globfit: Consistently fitting primitives by discovering global relations, ACM Transactions on Graphics, vol.30, issue.52, pp.1-5212, 2011. ,
Growing least squares for the analysis of manifolds in scale-space, Comp. Graph. Forum, vol.31, pp.5-1691, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00713678
Multicriteria Decision Aid and Artificial Intelligence: Links, Theory and Applications, 2013. ,
DOI : 10.1002/9781118522516
Illustrating how mechanical assemblies work, ACM Transactions on Graphics, vol.29, issue.58, pp.1-5812, 2010. ,
Structure-aware shape processing, ACM SIGGRAPH 2014 Courses, pp.141-154, 2014. ,
An Optimization Approach to Improving Collections of Shape Maps, Eurographics Symposium on Geometry Processing (SGP), pp.1481-1491, 2011. ,
DOI : 10.1111/j.1467-8659.2011.02022.x
Gcap: Graph-based automatic image captioning, Computer Vision and Pattern Recognition Workshop Conference on, pp.146-146, 2004. ,
The sun attribute database: Beyond categories for deeper scene understanding, Int. J. Comput. Vision, vol.108, pp.1-2, 2014. ,
A survey of graph theoretical approaches to image segmentation. Pattern Recogn, pp.1020-1038, 2013. ,
Interactive foreground extraction using iterated graph cuts, 2004. ,
On being the right scale: Sizing large collections of 3D models, 2014. ,
Efficient ransac for point-cloud shape detection, pp.214-226, 2007. ,
Shape recognition in 3d point-clouds, The 16-th International Conference in Central Europe on Computer Graphics, Visualization and Computer Vision, 2008. ,
Imagining the unseen, ACM Transactions on Graphics, vol.33, issue.6, 2014. ,
DOI : 10.1145/2661229.2661288
Textonboost for image understanding: Multi-class object recognition and segmentation by jointly modeling texture, layout , and context, International Journal of Computer Vision, vol.81, issue.1, pp.2-23, 2009. ,
Indoor segmentation and support inference from rgbd images, 2012. ,
Estimating image depth using shape collections, Transactions on Graphics, 2014. ,
A concise and provably informative multi-scale signature based on heat diffusion, Proceedings of the Symposium on Geometry Processing, pp.1383-1392, 2009. ,
Co-hierarchical analysis of shape structures, ACM Transactions on Graphics, vol.32, issue.4, pp.1-6910, 2013. ,
DOI : 10.1145/2461912.2461924
Smartannotator: An interactive tool for annotating rgbd indoor images, 2014. ,
Semantics-preserving bag-of-words models for efficient image annotation, Proceedings of the First ACM Workshop on Large-scale Multimedia Retrieval and Mining-MMRM '09, pp.19-26, 2009. ,
Hierarchical semantic labeling for task-relevant rgb-d perception, Robotics: Science and Systems (RSS), 2014. ,
Organizing heterogeneous scene collection through contextual focal points, Proc. of SIGGRAPH 2014) 33, 2014. ,
Feature correlation hypergraph: Exploiting high-order potentials for multimodal recognition, pp.1408-1419, 2014. ,
Beyond point clouds: Scene understanding by reasoning geometry and physics, 2013. ,
Smart variations: Functional substructures for part compatibility, Computer Graphics Forum (Eurographics), vol.32, issue.2, pp.195-204, 2013. ,
Recurring part arrangements in shape collections, Computer Graphics Forum, 2014. ,
High-quality video view interpolation using a layered representation, ACM SIGGRAPH, p.600608, 2004. ,
Learning the visual interpretation of sentences, Proceedings of the 2013 IEEE International Conference on Computer Vision, pp.1681-1688, 2013. ,
