Unify and conquer (garbage, updating, aliasing, . . . ) in functional languages, Lisp and Functional Programming, 1990. ,
DOI : 10.1145/91556.91652
Making set-constraint based program analyses scale, 1996. ,
Program analysis using mixed term and set constraints, Static Analysis Symposium '97, number 1302 in LNCS, pp.114-126, 1997. ,
DOI : 10.1007/BFb0032737
Tracking down exceptions in Standard ML programs, 1998. ,
Partial online cycle elimination in inclusion constraint graphs, pp.85-96, 1998. ,
Componential set-based analysis, Prog. Lang. Design and Impl, 1997. ,
DOI : 10.1145/316686.316703
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.6615
Refinement types for ML, Prog. Lang. Design and Impl, pp.268-277, 1991. ,
DOI : 10.1145/113445.113468
A type system for exceptions, Proc. 1994 workshop on ML and its applications, pp.127-135, 1994. ,
Set-based analysis of ML programs, Lisp and Functional Programming '94, pp.306-317, 1994. ,
DOI : 10.1145/182409.182495
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA270597
Global tagging optimization by type inference, Lisp and Functional Programming, 1992. ,
DOI : 10.1145/141478.141542
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.388.6583
Type inference with polymorphic recursion, ACM Transactions on Programming Languages and Systems, vol.15, issue.2, pp.253-289, 1993. ,
DOI : 10.1145/169701.169692
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.388.430
Polymorphic splitting: An effective polyvariant flow analysis, ACM Trans. Prog. Lang. Syst, vol.20, issue.1, pp.166-207, 1998. ,
Type reconstruction in the presence of polymorphic recursion, ACM Transactions on Programming Languages and Systems, vol.15, issue.2 ,
DOI : 10.1145/169701.169687
Type-based analysis of uncaught exceptions, ACM Transactions on Programming Languages and Systems, vol.22, issue.2, 1998. ,
DOI : 10.1145/349214.349230
URL : https://hal.archives-ouvertes.fr/hal-01499959
The Objective Caml system. Software and documentation available on the Web, 1996. ,
Polymorphic effect systems, Proceedings of the 15th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '88, pp.47-57, 1988. ,
DOI : 10.1145/73560.73564
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.73.4916
Polymorphic type schemes and recursive definitions, International Symposium on Programming , number 167 in LNCS, pp.217-228, 1984. ,
DOI : 10.1007/3-540-12925-1_41
A polymorphic record calculus and its compilation, ACM Transactions on Programming Languages and Systems, vol.17, issue.6, pp.844-895, 1995. ,
DOI : 10.1145/218570.218572
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.26.4611
A framework for type inference with subtyping, Int. Conf. on Functional Progr, pp.228-238, 1996. ,
DOI : 10.1145/291251.289448
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.55.2364
Type inference in the presence of subtyping: from theory to practice, Research report, vol.3483, 1998. ,
URL : https://hal.archives-ouvertes.fr/inria-00073205
Objective ML, Proceedings of the 24th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '97, pp.40-53, 1997. ,
DOI : 10.1145/263699.263707
Records and variants as a natural extension of ML, 16th symp. Principles of Progr. Lang, pp.77-88, 1989. ,
Syntactic theories and the algebra of record terms, 1993. ,
Type inference for records in a natural extension of ML, Theoretical Aspects of Object-Oriented Programming, 1993. ,
Smartest recompilation, Proceedings of the 20th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '93, pp.439-450, 1993. ,
DOI : 10.1145/158511.158702
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.8113
Control-Flow Analysis of Higher-Order Languages, 1991. ,
Points-to analysis in almost linear time, Proceedings of the 23rd ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '96, pp.32-41, 1996. ,
DOI : 10.1145/237721.237727
The Type and Effect Discipline, Information and Computation, vol.111, issue.2, pp.245-296, 1994. ,
DOI : 10.1006/inco.1994.1046
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.54.5309
A region inference algorithm, ACM Transactions on Programming Languages and Systems, vol.20, issue.4, 1998. ,
DOI : 10.1145/291891.291894
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.9171
Region-Based Memory Management, Information and Computation, vol.132, issue.2, pp.109-176, 1997. ,
DOI : 10.1006/inco.1996.2613
URL : http://doi.org/10.1006/inco.1996.2613
Complete type inference for simple objects, Logic in Computer Science, pp.37-44, 1987. ,
DOI : 10.1109/lics.1988.5111
A practical soft type system for scheme, ACM Transactions on Programming Languages and Systems, vol.19, issue.1, pp.87-152, 1997. ,
DOI : 10.1145/239912.239917
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.4251
A Syntactic Approach to Type Soundness, Information and Computation, vol.115, issue.1, pp.38-94, 1994. ,
DOI : 10.1006/inco.1994.1093
URL : http://doi.org/10.1006/inco.1994.1093
Simple imperative polymorphism, Lisp and Symbolic Computation, pp.343-356, 1995. ,
DOI : 10.1007/BF01018828
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.37.5096
Towards a cost-effective estimation of uncaught exceptions in SML programs, Static Analysis Symposium '97, number 1302 in LNCS, pp.98-113, 1997. ,
DOI : 10.1007/BFb0032736
An abstract interpretation for estimating uncaught exceptions in Standard ML programs, Science of Computer Programming, vol.31, issue.1, pp.147-173, 1998. ,
DOI : 10.1016/S0167-6423(96)00044-5
