Polymorphism by name for references and continuations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
This article investigates an ML-like language with by-name semantics for polymorphism: polymorphic objects are not evaluated once for all at generalization time, but re-evaluated at each specialization. Unlike the standard ML semantics, the by-name semantics works well with polymorphic references and polymorphic continuations: the naive typing rules for references and for continuations are sound with respect to this semantics. Poly-morphism by name leads to a better integration of these imperative features into the ML type discipline. Practical experience shows that it retains most of the efficiency and predictability of polymorphism by value.
polymorphism-by-name.pdf (180.45 Ko) Télécharger le fichier
hal-01499970 , version 1 (01-04-2017)
Xavier Leroy. Polymorphism by name for references and continuations. POPL 1993: 20th symposium Principles of Programming Languages, Jan 1993, Charleston, United States. pp.220-231, ⟨10.1145/158511.158632⟩. ⟨hal-01499970⟩
188 Consultations
218 Téléchargements
