Dynamics in ML - Archive ouverte HAL Access content directly
Journal Articles Journal of Functional Programming Year : 1993
Dynamics in ML
Objects with dynamic types allow the integration of operations that essentially require run-time type-checking into statically-typed languages. This article presents two extensions of the ML language with dynamics, based on our work on the CAML implementation of ML, and discusses their usefulness. The main novelty of this work is the combination of dynamics with polymorphism.
dynamics-in-ML.pdf (233.47 Ko) Télécharger le fichier
Dates and versions
hal-01499972 , version 1 (01-04-2017)
Identifiers
Cite
Xavier Leroy, Michel Mauny. Dynamics in ML. Journal of Functional Programming, 1993, 3 (4), pp.431-463. ⟨10.1017/S0956796800000848⟩. ⟨hal-01499972⟩
115 View
79 Download
Share
