Compilers: principles, techniques, and tools, 1986. ,
Run-time tags aren't necessary, Lisp and Symbolic Computation, 1989. ,
DOI : 10.1007/bf01811537
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.42.595
Compiling with continuations, 1992. ,
DOI : 10.1017/CBO9780511609619
A standard ML compiler, In Functional Programming Languages and Computer Architecture Lecture Notes in Computer Science, vol.242, 1987. ,
DOI : 10.1007/3-540-18317-5_17
Compacting garbage collector with ambiguous roots, 1988. ,
DOI : 10.1145/1317224.1317225
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.295.5356
The functional abstract machine, Polymorphism, vol.1, issue.1, 1983. ,
On understanding types, data abstraction, and polymorphism. Computing surveys, pp.471-522, 1985. ,
DOI : 10.1145/6041.6042
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.117.695
Register allocation by priority-based coloring, SIGPLAN Notices, vol.19, issue.6, 1984. ,
DOI : 10.1145/502949.502896
The categorical abstract machine, Science of Computer Programming, vol.8, issue.2, pp.173-202, 1987. ,
DOI : 10.1016/0167-6423(87)90020-7
URL : http://dx.doi.org/10.1016/0167-6423(87)90020-7
Principal type-schemes for functional programs, Proceedings of the 9th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '82, pp.207-212, 1982. ,
DOI : 10.1145/582153.582176
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.645.5233
The definition of Standard ML, 1990. ,
An ad hoc approach to the implementation of polymorphism, ACM Trans. Prog. Lang. Syst, vol.13, issue.3, 1991. ,
Unboxed values as first-class citizens, Functional Programming Languages and Computer Architecture, 1991. ,
Coercive type isomorphism, In Functional Programming Languages and Computer Architecture Lecture Notes in Computer Science, vol.523, 1991. ,
DOI : 10.1007/3540543961_3
Type inference for polymorphic references . Information and Computation, 1990. ,
DOI : 10.1016/0890-5401(90)90018-d
URL : http://doi.org/10.1016/0890-5401(90)90018-d
Programming in Modula-2, 1983. ,
DOI : 10.1007/978-3-642-96878-5
