Manifest types, modules, and separate compilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
Xavier Leroy
This paper presents a variant of the SML module system that introduces a strict distinction between abstract types and manifest types (types whose definitions are part of the module specification), while retaining most of the expressive power of the SML module system. The resulting module system provides much better support for separate compilation .
manifest-types-popl.pdf (211 Ko) Télécharger le fichier
hal-01499976 , version 1 (01-04-2017)
Xavier Leroy. Manifest types, modules, and separate compilation. POPL 1994: 21st symposium Principles of Programming Languages, ACM, Jan 1994, Portland, United States. pp.109-122, ⟨10.1145/174675.176926⟩. ⟨hal-01499976⟩
39 Consultations
196 Téléchargements
