Ensemblebased simultaneous state and parameter estimation in a twodimensional sea-breeze model, Monthly Weather Review, issue.10, pp.1342951-2970, 2006. ,
An Ensemble Adjustment Kalman Filter for Data Assimilation, Monthly Weather Review, vol.129, issue.12, pp.2884-2903, 2001. ,
DOI : 10.1175/1520-0493(2001)129<2884:AEAKFF>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.5.9952
A Monte Carlo Implementation of the Nonlinear Filtering Problem to Produce Ensemble Assimilations and Forecasts, Monthly Weather Review, vol.127, issue.12, pp.2741-2758, 1999. ,
DOI : 10.1175/1520-0493(1999)127<2741:AMCIOT>2.0.CO;2
Local ensemble Kalman filtering in the presence of model bias, TellusA, issue.3, pp.58293-306, 2006. ,
Coupling Dynamic Equations and Satellite Images for Modelling Ocean Surface Circulation, Com. in Comp. and Inf. Science, vol.550, pp.191-205, 2015. ,
DOI : 10.1007/978-3-319-25117-2_12
URL : https://hal.archives-ouvertes.fr/hal-01245369
Weighted ensemble transform Kalman filter for image assimilation, Tellus A: Dynamic Meteorology and Oceanography, vol.132, issue.7, p.18803, 2013. ,
DOI : 10.3402/tellusa.v65i0.18803
URL : https://hal.archives-ouvertes.fr/hal-00793804
Data Assimilation for Geophysical Fluids, Handbook of Numerical Analysis, pp.385-441, 2009. ,
DOI : 10.1016/S1570-8659(08)00209-3
URL : https://hal.archives-ouvertes.fr/inria-00391892
Localization and the iterative ensemble Kalman smoother, Quarterly Journal of the Royal Meteorological Society, vol.133, issue.695, 2015. ,
DOI : 10.1002/qj.945
An iterative ensemble Kalman smoother, Quarterly Journal of the Royal Meteorological Society, vol.134, issue.682, pp.1401521-1535, 2013. ,
DOI : 10.1002/qj.2236
URL : https://hal.archives-ouvertes.fr/hal-00947740
Joint state and parameter estimation with an iterative ensemble Kalman smoother, Nonlinear Processes in Geophysics, vol.20, issue.5, pp.803-818, 2013. ,
DOI : 10.5194/npg-20-803-2013
URL : https://hal.archives-ouvertes.fr/hal-00877943
Finite-Volume Model for Shallow-Water Flooding of Arbitrary Topography, Journal of Hydraulic Engineering, vol.128, issue.3, pp.289-298, 2002. ,
DOI : 10.1061/(ASCE)0733-9429(2002)128:3(289)
Ensemble-derived stationary and flow-dependent background-error covariances: Evaluation in a quasi-operational NWP setting, Quarterly Journal of the Royal Meteorological Society, vol.130, issue.607, pp.1311013-1043, 2005. ,
DOI : 10.1256/qj.04.15
Intercomparison of Variational Data Assimilation and the Ensemble Kalman Filter for Global Deterministic NWP. Part I: Description and Single-Observation Experiments, Monthly Weather Review, vol.138, issue.5, pp.1550-1566, 2010. ,
DOI : 10.1175/2009MWR3157.1
Stochastic representation of model uncertainties in the ECMWF ensemble prediction system, Quarterly Journal of the Royal Meteorological Society, vol.8, issue.560, pp.2887-2908, 1999. ,
DOI : 10.1002/qj.49712556006
Computational Methods for Data Evaluation and Assimilation, 2013. ,
Accounting for observation errors in image data assimilation, Tellus A: Dynamic Meteorology and Oceanography, vol.127, issue.4, p.23629, 2015. ,
DOI : 10.3402/tellusa.v67.23629
URL : https://hal.archives-ouvertes.fr/hal-00984508
A particle filter to reconstruct a free-surface flow from a depth camera. Fluid Dynamics Research, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01223693
Pressure image assimilation for atmospheric motion estimation, TellusA, issue.1, pp.61160-178, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00273838
A strategy for operational implementation of 4D-Var, using an incremental approach, Quarterly Journal of the Royal Meteorological Society, vol.45, issue.519, pp.1367-1387, 1994. ,
DOI : 10.1002/qj.49712051912
A Stochastic Filtering Technique for Fluid Flow Velocity Fields Tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.7, pp.311278-1293, 2009. ,
DOI : 10.1109/TPAMI.2008.152
Stochastic equations in infinite dimensions, 1992. ,
Bias and data assimilation, Quarterly Journal of the Royal Meteorological Society, vol.125, issue.613, pp.3323-3343, 2005. ,
DOI : 10.1256/qj.05.137
Sequential data assimilation with a non linear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, J. Geophys. Res, vol.99, issue.C510, pp.143-162, 1994. ,
DOI : 10.1029/94jc00572
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.930
The Ensemble Kalman Filter: theoretical formulation and practical implementation, Ocean Dynamics, vol.53, issue.4, pp.343-367, 2003. ,
DOI : 10.1007/s10236-003-0036-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.5.6990
A comparison of 4DVar with ensemble data assimilation methods, Quarterly Journal of the Royal Meteorological Society, vol.26, issue.678, pp.140281-294, 2013. ,
DOI : 10.1002/qj.2135
Subgrid modelling for geophysical flows, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.55, issue.1910, p.37120120166, 1982. ,
DOI : 10.1098/rsta.2009.0192
Construction of correlation functions in two and three dimensions, Quarterly Journal of the Royal Meteorological Society, vol.4, issue.2, pp.723-757, 1999. ,
DOI : 10.1002/qj.49712555417
Novel approach to nonlinear/non-Gaussian Bayesian state estimation, IEE Proceedings F Radar and Signal Processing, vol.140, issue.2, 1993. ,
DOI : 10.1049/ip-f-2.1993.0015
A mechanism for catastrophic filter divergence in data assimilation for sparse observation networks, Nonlinear Processes in Geophysics, vol.20, issue.5, pp.705-712, 2013. ,
DOI : 10.5194/npg-20-705-2013
Balance and Ensemble Kalman Filter Localization Techniques, Monthly Weather Review, vol.139, issue.2, pp.511-522, 2011. ,
DOI : 10.1175/2010MWR3328.1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.382.9345
An Iterative Ensemble Kalman Filter for Multiphase Fluid Flow Data Assimilation, SPE Journal, vol.12, issue.04, pp.438-446, 2007. ,
DOI : 10.2118/108438-PA
Four-dimensional ensemble variational (4D-En-Var) data assimilation for the HIgh Resolution Limited Area Model (HIRLAM), Nonlinear Processes in Geophysics, vol.21, issue.4, pp.745-762, 2014. ,
DOI : 10.5194/npg-21-745-2014
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.28, issue.4, pp.369-393, 2010. ,
DOI : 10.1007/s00348-009-0778-3
URL : https://hal.archives-ouvertes.fr/hal-00456162
Efficient data assimilation for spatiotemporal chaos: A local ensemble transform Kalman filter, Physica D: Nonlinear Phenomena, vol.230, issue.1-2, pp.112-126, 2007. ,
DOI : 10.1016/j.physd.2006.11.008
URL : http://arxiv.org/abs/physics/0511236
Optimal Orthogonal Basis and Image Assimilation: Motion Modeling, 2013 IEEE International Conference on Computer Vision, 2013. ,
DOI : 10.1109/ICCV.2013.416
URL : https://hal.archives-ouvertes.fr/hal-00871330
Stochastic representation of the Reynolds transport theorem: revisiting large-scale modeling, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01394780
Accelerating the spin-up of Ensemble Kalman Filtering, Quarterly Journal of the Royal Meteorological Society, vol.58, issue.651, pp.1644-1651, 2010. ,
DOI : 10.1002/qj.652
???Variable localization??? in an ensemble Kalman filter: Application to the carbon cycle data assimilation, Journal of Geophysical Research, vol.58, issue.C5, p.116, 1984. ,
DOI : 10.1029/2010JD014673
Sensitivity of a shallow-water model to parameters, Nonlinear Analysis: Real World Applications, vol.13, issue.3, pp.1416-1428, 2012. ,
DOI : 10.1016/j.nonrwa.2011.11.006
URL : https://hal.archives-ouvertes.fr/hal-00652299
Reducing Forecast Errors Due to Model Imperfections Using Ensemble Kalman Filtering, Monthly Weather Review, vol.138, issue.8, pp.3316-3332, 2010. ,
DOI : 10.1175/2010MWR3067.1
Stochastic flows and stochastic differential equations, 1990. ,
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
Stochastic backscatter in a subgrid???scale model: Plane shear mixing layer, Physics of Fluids A: Fluid Dynamics, vol.2, issue.3, pp.1521-1530, 1990. ,
DOI : 10.1063/1.866606
Optimal control of systmes governed by PDEs, 1971. ,
An Ensemble-Based Four-Dimensional Variational Data Assimilation Scheme. Part I: Technical Formulation and Preliminary Test, Monthly Weather Review, vol.136, issue.9, pp.3363-3373, 2008. ,
DOI : 10.1175/2008MWR2312.1
Stochastic backscatter in large-eddy simulations of boundary layers, Journal of Fluid Mechanics, vol.91, issue.-1, pp.51-78, 1992. ,
DOI : 10.1175/1520-0469(1990)047 2.0.CO;2
Fluid flow dynamics under location uncertainty. Geophysical and Astrophysical Fluid Dynamics, pp.119-146, 2014. ,
Data assimilation into nonlinear stochastic models, Tellus A: Dynamic Meteorology and Oceanography, vol.11, issue.52, pp.167-194, 1999. ,
DOI : 10.3402/tellusa.v51i2.12315
Practical and theoretical aspects of adjoint parameter estimation and identifiability in meteorology and oceanography, Dynamics of Atmospheres and Oceans, vol.27, issue.1-4, pp.55-79, 1998. ,
DOI : 10.1016/S0377-0265(97)00032-8
A local ensemble Kalman filter for atmospheric data assimilation, pp.415-428, 2004. ,
Variational Assimilation of Fluid Motion from Image Sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, pp.343-363, 2008. ,
DOI : 10.1137/080713896
URL : https://hal.archives-ouvertes.fr/hal-00596149
Gravity wave drag estimation from global analyses using variational data assimilation principles. I: Theory and implementation, Quarterly Journal of the Royal Meteorological Society, vol.44, issue.609, pp.1311821-1840, 2005. ,
DOI : 10.1256/qj.04.116
Geophysical flows under location uncertainty, Part I Random transport and general models, Geophysical & Astrophysical Fluid Dynamics, vol.111, issue.3, 2016. ,
DOI : 10.1002/qj.49712757518
URL : https://hal.archives-ouvertes.fr/hal-01391420
Geophysical flows under location uncertainty, part II Quasigeostrophic models and efficient ensemble spreading, 2016. ,
DOI : 10.1080/03091929.2017.1312101
URL : http://arxiv.org/abs/1611.03041
Geophysical flows under location uncertainty, Part III SQG and frontal dynamics under strong turbulence conditions, Geophysical & Astrophysical Fluid Dynamics, vol.111, issue.3, 2016. ,
DOI : 10.1029/JC081i015p02641
URL : https://hal.archives-ouvertes.fr/hal-01391484
Parameter Estimation Using Ensemble-Based Data Assimilation in the Presence of Model Error, Monthly Weather Review, vol.143, issue.5, pp.1568-1582, 2015. ,
DOI : 10.1175/MWR-D-14-00017.1
Estimating Model Parameters with Ensemble-Based Data Assimilation: Parameter Covariance Treatment, Journal of the Meteorological Society of Japan. Ser. II, vol.91, issue.4, pp.453-469, 2013. ,
DOI : 10.2151/jmsj.2013-403
Large Eddy Simulation for Incompressible Flows. An Introduction, Measurement Science and Technology, vol.12, issue.10, 2006. ,
DOI : 10.1088/0957-0233/12/10/707
Relation between two common localisation methods for the EnKF, Computational Geosciences, vol.136, issue.2, pp.225-237, 2011. ,
DOI : 10.1007/s10596-010-9202-6
A deterministic formulation of the ensemble Kalman filter: an alternative to ensemble square root filters, Tellus A: Dynamic Meteorology and Oceanography, vol.130, issue.2, pp.361-371, 2008. ,
DOI : 10.1111/j.1600-0870.2007.00299.x
An Iterative EnKF for Strongly Nonlinear Systems, Monthly Weather Review, vol.140, issue.6, pp.1988-2004, 2012. ,
DOI : 10.1175/MWR-D-11-00176.1
Assimilating high-resolution winds from a Doppler lidar using an ensemble Kalman filter with lateral boundary adjustment, Tellus A: Dynamic Meteorology and Oceanography, vol.124, issue.1, pp.671-684, 2015. ,
DOI : 10.3402/tellusa.v64i0.11594
A kinetic energy backscatter algorithm for use in ensemble prediction systems, Quarterly Journal of the Royal Meteorological Society, vol.11, issue.612, pp.3079-3012, 2005. ,
DOI : 10.1256/qj.04.106
Experiences in multiyear combined state???parameter estimation with an ecosystem model of the North Atlantic and Arctic Oceans using the Ensemble Kalman Filter, Journal of Marine Systems, vol.152, issue.C, pp.1-17, 2015. ,
DOI : 10.1016/j.jmarsys.2015.07.004
Uncertainty in weather and climate prediction, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.50, issue.7024, pp.3694751-4767, 1956. ,
DOI : 10.1038/nature03301
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3270390
GENERAL CIRCULATION EXPERIMENTS WITH THE PRIMITIVE EQUATIONS, Monthly Weather Review, vol.91, issue.3, pp.99-164, 1963. ,
DOI : 10.1175/1520-0493(1963)091<0099:GCEWTP>2.3.CO;2
Assimilation of observations, an introduction, J. Meteor. Soc. Japan, 1997. ,
Offline parameter estimation using EnKF and maximum likelihood error covariance estimates: Application to a subgrid-scale orography parametrization, Quarterly Journal of the Royal Meteorological Society, vol.61, issue.687, pp.141383-395, 2014. ,
DOI : 10.1002/qj.2357
Assimilation of image sequences in numerical models, Tellus A: Dynamic Meteorology and Oceanography, vol.105, issue.8, pp.30-47, 2010. ,
DOI : 10.1111/j.1600-0870.2009.00416.x
URL : https://hal.archives-ouvertes.fr/inria-00332815
Simultaneous Estimation of Microphysical Parameters and Atmospheric State with Simulated Radar Data and Ensemble Square Root Kalman Filter. Part I: Sensitivity Analysis and Parameter Identifiability, Monthly Weather Review, vol.136, issue.5, pp.1630-1648, 2008. ,
DOI : 10.1175/2007MWR2070.1
The impact of initial spread calibration on the RELO ensemble and its application to Lagrangian dynamics, Nonlinear Processes in Geophysics, pp.621-641, 2013. ,
DOI : 10.5194/npg-20-621-2013
Using the ensemble Kalman filter to estimate multiplicative model parameters, TellusA, issue.5, pp.61601-609, 2009. ,
Enhanced ensemble-based 4DVar scheme for data assimilation, Computers & Fluids, vol.115, issue.C, pp.201-210, 2015. ,
DOI : 10.1016/j.compfluid.2015.03.025
URL : https://hal.archives-ouvertes.fr/hal-01144923
Impacts of Initial Estimate and Observation Availability on Convective-Scale Data Assimilation with an Ensemble Kalman Filter, Monthly Weather Review, vol.132, issue.5, pp.1238-1253, 2004. ,
DOI : 10.1175/1520-0493(2004)132<1238:IOIEAO>2.0.CO;2
Impact of Parameter Estimation on the Performance of the FSU Global Spectral Model Using Its Full-Physics Adjoint, Monthly Weather Review, vol.127, issue.7, pp.1497-1517, 1999. ,
DOI : 10.1175/1520-0493(1999)127<1497:IOPEOT>2.0.CO;2
Model Error Estimation Employing an Ensemble Data Assimilation Approach, Monthly Weather Review, vol.134, issue.5, pp.1337-1354, 2006. ,
DOI : 10.1175/MWR3125.1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.379.3407
