Non-local Conservation Law from Stochastic Particle Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
In this paper we consider an interacting particle system in R^d modelled as a system of N stochastic differential equations driven by Lévy processes. The limiting behaviour as the size N grows to infinity is achieved as a law of large numbers for the empirical density process associated with the interacting particle system. We prove that the empirical process converges, uniformly in the space variable, to the solution of the d-dimensional fractal conservation law.
Marielle-Christian-lastversion.pdf (448.27 Ko) Télécharger le fichier
hal-01502451 , version 1 (05-04-2017)
hal-01502451 , version 2 (20-09-2017)
Marielle Simon, Christian Olivera. Non-local Conservation Law from Stochastic Particle Systems. 2017. ⟨hal-01502451v1⟩
378 Consultations
212 Téléchargements
