Reports
A new parallelization scheme for the Hermite interpolation based gyroaverage operator
Nicolas Bouzat 1, 2 Fabien Rozar 2, 3 Guillaume Latu 3 Jean Roman 4, 2
1 TONUS - TOkamaks and NUmerical Simulations
IRMA - Institut de Recherche Mathématique Avancée, Inria Nancy - Grand Est
2 HiePACS - High-End Parallel Algorithms for Challenging Numerical Simulations
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest
Abstract : Gyrokinetic modeling is appropriate for describing plasma turbulence in the core of Tokamaks, and the gyroaverage operator is a cornerstone of this approach. In a gyrokinetic code the gyroaveraging scheme needs to be accurate enough, but also requires a low computational cost because it is often applied on the main unknown, namely the 5D guiding-center distribution function, as well as on several 3D fields. The current gyroaverage implementation used in the Gysela code has recently been improved, enhancing the precision of the operator thanks to Hermite interpolation. In the present paper, we describe a new parallelization scheme for the gyroaverage operator. It mainly avoids costly transpositions of the full 5D function using halo exchange instead. Though the computational cost remains the same, the communication one is much smaller. The overall algorithm is also improved by cleverly interleaving communications and computations, thus allowing for a reduction of communication costs and a more efficient thread parallelization. The execution time with this algorithm is up to twice as fast as the previous version. The benefit of an improved scheme providing the overlap of communications by computations is also shown, again improving execution times. The description of the algorithms is given, together with an analysis of the achieved performance.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01502513
Contributor : Nicolas Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, April 5, 2017 - 4:11:28 PM
Last modification on : Friday, June 19, 2020 - 9:22:05 AM
Long-term archiving on: : Thursday, July 6, 2017 - 1:44:39 PM
File
RR-9054.pdf
Identifiers
  • HAL Id : hal-01502513, version 1
Citation
Nicolas Bouzat, Fabien Rozar, Guillaume Latu, Jean Roman. A new parallelization scheme for the Hermite interpolation based gyroaverage operator. [Research Report] RR-9054, Inria. 2017, pp.22. ⟨hal-01502513⟩
Share
Metrics
Record views
13816
Files downloads
275
