On the variational formulation of some stationary second order mean field games systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
On the variational formulation of some stationary second order mean field games systems. 2017. ON THE VARIATIONAL FORMULATION OF SOME STATIONARY SECOND ORDER MEAN FIELD GAMES SYSTEMS ALP´ARALP´ ALP´AR RICH´ARDRICH´ RICH´ARD M ´ ESZ´AROSESZ´ ESZ´AROS AND FRANCISCO J. SILVA Abstract. We consider the variational approach to prove the existence of solutions of second order stationary Mean Field Games on a bounded domain Ω ⊆ R d , with Neumann boundary conditions, and with and without density constraints. We consider Hamiltonians which growth as ⋅ q ′ , where q ′ = q(q − 1) and q > d. Despite this restriction, our approach allows us to prove the existence of solutions in the case of rather general coupling terms. When density constraints are taken into account, our results improve those in [MS15]. Furthermore, our approach can be used to obtain solutions of systems with multiple populations.
alpar_francisco_FINAL.pdf (641.55 Ko) Télécharger le fichier
hal-01502723 , version 2 (06-04-2017)
hal-01502723 , version 3 (08-04-2017)
hal-01502723 , version 4 (17-04-2017)
hal-01502723 , version 1 (31-08-2018)
  • HAL Id : hal-01502723 , version 1
Alpár Richard Mészáros, Francisco José Silva. On the variational formulation of some stationary second order mean field games systems. 2018. ⟨hal-01502723v1⟩
364 Consultations
281 Téléchargements
