Flow fields: Dense correspondence fields for highly accurate large displacement optical flow estimation, ICCV, pp.4015-4023, 2015. ,
A naturalistic open source movie for optical flow evaluation, ECCV, pp.611-625, 2012. ,
Libsvm: a library for support vector machines, ACM Transactions on Intelligent Systems and Technology, vol.2, issue.3, p.27, 2011. ,
Full flow: Optical flow estimation by global optimization over regular grids, 2016. ,
Two-frame motion estimation based on polynomial expansion, Scandinavian conference on Image analysis, pp.363-370, 2003. ,
Optical flow modeling and computation: a survey, Computer Vision and Image Understanding, vol.134, pp.1-21, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01104081
Facial grid transformation: A novel face registration approach for improving facial action unit recognition, ICIP, pp.1415-1419, 2014. ,
Spontaneous facial micro-expression recognition using discriminative spatiotemporal local binary pattern with an improved integral projection, 2016. ,
Spontaneous facial micro-expression analysis using spatiotemporal completed local quantized patterns, Neurocomputing, vol.175, pp.564-578, 2016. ,
Decision level fusion of domain specific regions for facial action recognition, ICPR, pp.1776-1781, 2014. ,
One millisecond face alignment with an ensemble of regression trees, CVPR, pp.1867-1874, 2014. ,
Texture and shape information fusion for facial expression and facial action unit recognition, Pattern Recognition, vol.41, issue.3, pp.833-851, 2008. ,
Sparse localized facial motion dictionary learning for facial expression recognition, International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3548-3552, 2014. ,
A spontaneous micro-expression database: Inducement, collection and baseline, FG, 2013. ,
Learning spatial weighting for facial expression analysis via constrained quadratic programming, Pattern Recognition, vol.46, issue.11, pp.3103-3116, 2013. ,
A main directional mean optical flow feature for spontaneous micro-expression recognition, 2015. ,
The extended cohn-kanade dataset (ck+): A complete dataset for action unit and emotion-specified expression, CVPR Workshops, pp.94-101, 2010. ,
Dynamic texture recognition using normal flow and texture regularity, Iberian Conference on Pattern Recognition and Image Analysis, pp.223-230, 2005. ,
Epicflow: Edge-preserving interpolation of correspondences for optical flow, CVPR, pp.1164-1172, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01142656
A simple approach to facial expression recognition, Proc. of the WSEAS Conference on Computer Engineering and Applications, pp.456-461, 2007. ,
, , 2014.
, Micro-expression recognition using dynamic textures on tensor independent color space, ICPR, pp.4678-4683
Micro-expression recognition using robust principal component analysis and local spatiotemporal directional features, ECCV Workshop, pp.325-338, 2014. ,
DOI : 10.1007/978-3-319-16178-5_23
Lbp with six intersection points: Reducing redundant information in lbp-top for micro-expression recognition, Asian Conference on Computer Vision, pp.525-537, 2014. ,
DOI : 10.1007/978-3-319-16865-4_34
Automatic facial expression recognition for intelligent tutoring systems, CVPR Workshops, 2008. ,
DOI : 10.1109/cvprw.2008.4563182
Casme ii: An improved spontaneous micro-expression database and the baseline evaluation, PloS one, issue.1, p.9, 2014. ,
DOI : 10.1371/journal.pone.0086041
URL : https://journals.plos.org/plosone/article/file?id=10.1371/journal.pone.0086041&type=printable
Active and dynamic information fusion for facial expression understanding from image sequences, vol.27, pp.699-714, 2005. ,
Learning active facial patches for expression analysis, CVPR, pp.2562-2569, 2012. ,
