Plasma Physics via Computer Simulation, 1985. ,
DOI : 10.1887/0750301171
Helicity dissipation in 3d PIC simulation of magnetic reconnection of a force free configuration, 45th Annual Meeting of the APS Division of Plasma Physics, 2003. ,
Ultrahigh performance threedimensional electromagnetic relativistic kinetic plasma simulation, Physics of Plasmas, vol.155, p.55703, 2008. ,
DOI : 10.1063/1.2840133
Optimization of particle-in-cell simulations for Vlasov-Poisson system with strong magnetic field, ESAIM: Proceedings and Surveys 53, pp.177-190, 2016. ,
DOI : 10.1051/proc/201653011
URL : https://hal.archives-ouvertes.fr/hal-01231444
Nonlinear array layouts for hierarchical memory systems, Proceedings of the 13th international conference on Supercomputing , ICS '99, pp.444-453, 1999. ,
DOI : 10.1145/305138.305231
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.2187
Particle-in-Cell algorithms for emerging computer architectures, Computer Physics Communications, vol.185, issue.3, pp.708-719, 2014. ,
DOI : 10.1016/j.cpc.2013.10.013
URL : http://doi.org/10.1016/j.cpc.2013.10.013
Optimization of particle-in-cell codes on reduced instruction set computer processors, Computers in Physics, vol.10, issue.3, pp.290-298, 1996. ,
DOI : 10.1063/1.168571
Empirical Analysis of Space-Filling Curves for Scientific Computing Applications, 2013 42nd International Conference on Parallel Processing, pp.170-179, 2013. ,
DOI : 10.1109/ICPP.2013.26
The Design and Implementation of FFTW3, Proceedings of the IEEE 93, pp.216-231, 2005. ,
DOI : 10.1109/JPROC.2004.840301
Cache-Oblivious Algorithms, Proceedings of the 40th Annual Symposium on Foundations of Computer Science, pp.285-299, 1999. ,
DOI : 10.1109/sffcs.1999.814600
The Plasma Simulation Code: A modern particle-in-cell code with patch-based load-balancing, Journal of Computational Physics, vol.318, pp.305-326, 2016. ,
DOI : 10.1016/j.jcp.2016.05.013
Ueber die stetige Abbildung einer Line auf ein Fl?chenst?ck, Mathematische Annalen, vol.38, issue.3, pp.459-460, 1891. ,
DOI : 10.1007/BF01199431
Memory Bandwidth and Machine Balance in Current High Performance Computers, IEEE Computer Society Technical Committee on Computer Architecture (TCCA) Newsletter, pp.19-25, 1995. ,
Improving Memory Hierarchy Performance for Irregular Applications Using Data and Computation Reorderings, International Journal of Parallel Programming, vol.293, pp.217-247, 2001. ,
DOI : 10.1145/305138.305228
URL : http://cacs.usc.edu/education/cs596/Mellor-opt-ISC99.pdf
A computer oriented geodetic data base and a new technique in file sequencing, In: IBM Germany Scientific Symposium Series, 1966. ,
Converting to and from Dilated Integers, IEEE Transactions on Computers, vol.57, issue.4, pp.567-573, 2008. ,
DOI : 10.1109/TC.2007.70814
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.92.7899
Programming the Hilbert curve, AIP Conference Proceedings, pp.381-387, 2004. ,
DOI : 10.1063/1.1751381
An efficient and portable SIMD algorithm for charge/current deposition in Particle-In-Cell codes, Computer Physics Communications, vol.210, pp.145-154, 2016. ,
DOI : 10.1016/j.cpc.2016.08.023
URL : https://hal.archives-ouvertes.fr/cea-01426502
