Applied Functional Analysis, 1981. ,
Analysis and Design of Integral Sliding Manifolds for Systems With Unmatched Perturbations, IEEE Transactions on Automatic Control, vol.51, issue.5, pp.853-858, 2006. ,
DOI : 10.1109/TAC.2006.875008
State Estimation for Dynamic Systems, Boca Raton, 1994. ,
Sliding Mode Control: Theory And Applications, 1998. ,
Sliding mode stabilization of uncertain systems using only output information, International Journal of Control, vol.35, issue.5, pp.1129-1144, 1995. ,
DOI : 10.1007/BFb0033675
Ellipsoidal calculus for estimation and control, 1997. ,
DOI : 10.1007/978-1-4612-0277-6
Infinite Dimensional Systems??? Sliding Motions, European Journal of Control, vol.8, issue.6, pp.508-518, 2002. ,
DOI : 10.3166/ejc.8.508-516
Sliding modes in banach spaces, Differential and Integral Equations, pp.167-189, 2002. ,
Existence of sliding motions for nonlinear evolution equations in banach space. Discrete and Continuous Dynamical Systems, special issue, pp.477-487, 2013. ,
Optimal algorithms theory for robust estimation and prediction, IEEE Transactions on Automatic Control, vol.30, issue.8, pp.730-738, 1985. ,
DOI : 10.1109/TAC.1985.1104056
Application of lyapunov method in distributed systems, Automation and Remote Control, vol.44, pp.426-430, 1983. ,
Discontinuous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2008. ,
Boundary control and observer design for an uncertain wave process by second-order sliding-mode technique, 52nd IEEE Conference on Decision and Control, 2013. ,
DOI : 10.1109/CDC.2013.6759926
Use of sliding modes in distributed system control problems. Automation and Remote Control, pp.1127-1135, 1982. ,
Boundary second-order sliding-mode control of an uncertain heat process with unbounded matched perturbation, Automatica, vol.48, issue.8, pp.1768-1775, 2012. ,
DOI : 10.1016/j.automatica.2012.05.041
Invariant ellipsoid method for minimization of unmatched disturbances effects in sliding mode control, Automatica, vol.47, issue.7, pp.47-1450, 2011. ,
DOI : 10.1016/j.automatica.2011.02.013
Mini???Max Integral Sliding-Mode Control for Multimodel Linear Uncertain Systems, IEEE Transactions on Automatic Control, vol.49, issue.1, pp.97-102, 2004. ,
DOI : 10.1109/TAC.2003.821412
Variable Structure Systems: from Principles to Implementation, volume 66 of IEE Control Series, chapter Deterministic output noise effects in sliding mode observation, pp.45-78, 2004. ,
Sliding Mode Control and Observation, 2014. ,
DOI : 10.1007/978-0-8176-4893-0
Sliding Modes in Control and Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
URL : http://doi.org/10.1080/10241230306724
State estimation for a dynamical system described by a linear equation with unknown parameters, Ukrainian Mathematical Journal, vol.1, issue.4, pp.214-235, 2009. ,
DOI : 10.1007/s11253-009-0210-4
Kalman Duality Principle for a Class of Ill-Posed Minimax Control Problems with Linear Differential-Algebraic Constraints, Applied Mathematics & Optimization, vol.14, issue.1, pp.289-309, 2013. ,
DOI : 10.1007/s00245-013-9207-3
On output-based sliding mode control design using minimax observer, 2014 13th International Workshop on Variable Structure Systems (VSS), 2014. ,
DOI : 10.1109/VSS.2014.6881096
URL : https://hal.archives-ouvertes.fr/hal-01071233
On output-based sliding mode control design using minimax observer, 2014 13th International Workshop on Variable Structure Systems (VSS), 2015. ,
Variable Structure Systems: from principles to implementation, chapter Minimax Observer for Sliding Mode Control Design, 2016. ,
DOI : 10.1049/pbce102e_ch2.2
Note on Minimax Sliding Mode Control Design for Linear Systems, IEEE Transactions on Automatic Control, 2017. ,
DOI : 10.1109/TAC.2016.2612058
URL : https://hal.archives-ouvertes.fr/hal-01371091
