Weak and strong formulations for the time-harmonic eddy-current problem in general multi-connected domains, European Journal of Applied Mathematics, vol.14, issue.4, pp.387-406, 2003. ,
DOI : 10.1017/S0956792503005151
Vector potentials in three-dimensional non-smooth domains, Mathematical Methods in the Applied Sciences, vol.2, issue.9, pp.823-864, 1998. ,
DOI : 10.1002/mma.1670020103
URL : http://onlinelibrary.wiley.com/doi/10.1002/(SICI)1099-1476(199806)21:9<823::AID-MMA976>3.0.CO;2-B/pdf
The Mathematical Analysis of Electrical and Optical Wave-Motion on the basis of Maxwell's Equations, 1915. ,
FEM calculation of eddy current losses and forces in thin conducting sheets of test facilities for fusion reactor components, IEEE Transactions on Magnetics, vol.28, issue.2, pp.1509-1512, 1992. ,
DOI : 10.1109/20.123983
Electromagnétisme, en vue de la modélisation, ) [Mathematics & Applications, 1993. ,
A Justification of Eddy Currents Model for the Maxwell Equations, SIAM Journal on Applied Mathematics, vol.60, issue.5, pp.1805-1823, 2000. ,
DOI : 10.1137/S0036139998348979
On the influence of the geometry on skin effect in electromagnetism, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.9-12, pp.9-121053, 2011. ,
DOI : 10.1016/j.cma.2010.11.011
URL : https://hal.archives-ouvertes.fr/hal-00503170
Singularities of eddy current problems, ESAIM: Mathematical Modelling and Numerical Analysis, vol.92, issue.5, pp.807-831, 2003. ,
DOI : 10.1017/S0308210500020023
URL : http://www.esaim-m2an.org/articles/m2an/pdf/2003/05/m2an0325.pdf
Abstract, Communications in Computational Physics, vol.144, issue.01, pp.213-238, 2014. ,
DOI : 10.1088/0031-9155/46/1/315
Differential forms on riemannian manifolds, Communications on Pure and Applied Mathematics, vol.60, issue.4, pp.551-590, 1955. ,
DOI : 10.1007/978-3-642-47434-7
Dual formulations for the modeling of thin electromagnetic shells using edge elements, IEEE Transactions on Magnetics, vol.36, issue.4, pp.799-803, 2000. ,
DOI : 10.1109/20.877566
Finite element methods for Navier-Stokes equations: theory and algorithms. Springer series in computational mathematics, 1986. ,
DOI : 10.1007/978-3-642-61623-5
Symmetric Coupling for Eddy Current Problems, SIAM Journal on Numerical Analysis, vol.40, issue.1, pp.41-65, 2002. ,
DOI : 10.1137/S0036142900380467
URL : http://www.uni-tuebingen.de/uni/opx/reports/hiptmair_148.ps.gz
Impedance boundary condition for vector potentials on thin layers and its application to integral equations, The European Physical Journal Applied Physics, vol.1, issue.1, pp.103-109, 1998. ,
DOI : 10.1051/epjap:1998123
Modeling of resistive sheets in finite element solutions (EM scattering), IEEE Transactions on Antennas and Propagation, vol.40, issue.6, pp.727-731, 1992. ,
DOI : 10.1109/8.144609
Non-specular radar cross section study, 1974. ,
Thin layers in electrical engineering-example of shell models in analysing eddy-currents by boundary and finite element methods, IEEE Transactions on Magnetics, vol.29, issue.2, pp.1450-1455, 1993. ,
DOI : 10.1109/20.250676
A skin effect approximation for eddy current problems, Archive for Rational Mechanics and Analysis, vol.10, issue.2, pp.87-98, 1985. ,
DOI : 10.1007/BF00281588
Solution procedures for three-dimensional eddy current problems, Journal of Mathematical Analysis and Applications, vol.101, issue.2, pp.348-379, 1984. ,
DOI : 10.1016/0022-247X(84)90108-2
On calculation of 3-D eddy currents in conducting and magnetic shells, IEEE Transactions on Magnetics, vol.31, issue.3, pp.1319-1324, 1995. ,
DOI : 10.1109/20.376271
Strongly Elliptic Systems and Boundary Integral Equations, 2000. ,
Computation of three-dimensional eddy currents in thin conductors, IEEE Transactions on Magnetics, vol.18, issue.2, pp.456-460, 1982. ,
DOI : 10.1109/TMAG.1982.1061860
3D magnetic field analysis using special elements, IEEE Transactions on Magnetics, vol.26, issue.5, pp.2379-2381, 1990. ,
DOI : 10.1109/20.104737
URL : http://ousar.lib.okayama-u.ac.jp/files/public/3/30174/20160528022809702443/fulltext.pdf
Acoustic and electromagnetic equations : integral representations for harmonic problems Applied mathematical sciences, 2001. ,
Equivalent Transmission Conditions for the Time-Harmonic Maxwell Equations in 3D for a Medium with a Highly Conductive Thin Sheet, SIAM Journal on Applied Mathematics, vol.76, issue.3, pp.1031-1052, 2016. ,
DOI : 10.1137/15M1012116
Solution of quasi-stationary field problems by means of magnetic scalar potential, IEEE Transactions on Magnetics, vol.19, issue.6, pp.2425-2428, 1983. ,
DOI : 10.1109/TMAG.1983.1062878
Finite element method for 3D eddy current flow in thin conducting sheets, IEE Proceedings A Physical Science, Measurement and Instrumentation, Management and Education, Reviews, vol.135, issue.6, pp.369-374, 1988. ,
DOI : 10.1049/ip-a-1.1988.0059
A Unified Analysis of Transmission Conditions for Thin Conducting Sheets in the Time-Harmonic Eddy Current Model, SIAM Journal on Applied Mathematics, vol.73, issue.6, pp.1980-2003, 2013. ,
DOI : 10.1137/120901398
Robust Transmission Conditions of High Order for Thin Conducting Sheets in Two Dimensions, IEEE Transactions on Magnetics, vol.50, issue.2, pp.41-44, 2014. ,
DOI : 10.1109/TMAG.2013.2285437
Asymptotic boundary element methods for thin conducting sheets, Discrete Contin. Dyn. Syst. Ser. S, vol.8, issue.3, pp.619-647, 2015. ,
Approximate boundary conditions, IEEE Transactions on Antennas and Propagation, vol.29, issue.5, pp.826-829, 1981. ,
DOI : 10.1109/TAP.1981.1142657
Analysis of three-dimensional electromagnetic fields, 1974. ,
