A new approach for determining low-frequency normal modes in macromolecules, Biopolymers, vol.81, issue.6, pp.759-771, 1994. ,
DOI : 10.1002/bip.360340608
Building-block approach for determining low-frequency normal modes of macromolecules, Proteins: Structure, Function, and Genetics, vol.77, issue.1, pp.1-7, 2000. ,
DOI : 10.1002/1097-0134(20001001)41:1<1::AID-PROT10>3.0.CO;2-P
Molecular Vibrations: The Theory of Infrared and Raman Vibrational Spectra, Journal of The Electrochemical Society, vol.102, issue.9, 1955. ,
DOI : 10.1149/1.2430134
Normal Mode Analysis of Biomolecular Structures: Functional Mechanisms of Membrane Proteins, Chemical Reviews, vol.110, issue.3, pp.1463-1497, 2010. ,
DOI : 10.1021/cr900095e
THE CONFORMATION PROPERTIES OF PROTEINS IN SOLUTION, Biological Reviews, vol.200, issue.4, pp.389-437, 1979. ,
DOI : 10.1002/anie.197707661
The dynamic picture of protein structure, Accounts of Chemical Research, vol.16, issue.6, pp.187-193, 1983. ,
DOI : 10.1021/ar00090a001
Dynamics of Proteins: Elements and Function, Annual Review of Biochemistry, vol.52, issue.1, pp.263-300, 1983. ,
DOI : 10.1146/annurev.bi.52.070183.001403
Intrinsic dynamics of enzymes in the unbound state and relation to allosteric regulation, Current Opinion in Structural Biology, vol.17, issue.6, pp.633-640, 2007. ,
DOI : 10.1016/j.sbi.2007.09.011
Essential dynamics of proteins, Proteins: Structure, Function, and Genetics, vol.158, issue.4, pp.412-425, 1993. ,
DOI : 10.1002/prot.340170408
Harmonic dynamics of proteins: normal modes and fluctuations in bovine pancreatic trypsin inhibitor., Proceedings of the National Academy of Sciences, vol.80, issue.21, pp.6571-6575, 1983. ,
DOI : 10.1073/pnas.80.21.6571
The normal modes of a protein: Native bovine pancreatic trypsin inhibitor, International Journal of Quantum Chemistry, vol.22, issue.S10, pp.181-199, 1983. ,
DOI : 10.1002/qua.560240721
Anisotropy of Fluctuation Dynamics of Proteins with an Elastic Network Model, Biophysical Journal, vol.80, issue.1, pp.505-515, 2001. ,
DOI : 10.1016/S0006-3495(01)76033-X
Analysis of domain motions by approximate normal mode calculations, Proteins: Structure, Function, and Genetics, vol.14, issue.3, pp.417-429, 1998. ,
DOI : 10.1002/(SICI)1097-0134(19981115)33:3<417::AID-PROT10>3.0.CO;2-8
Conformational change of proteins arising from normal mode calculations, Protein Engineering Design and Selection, vol.14, issue.1, pp.1-6, 2001. ,
DOI : 10.1093/protein/14.1.1
Efficient Generation of Feasible Pathways for Protein Conformational Transitions, Biophys. J, vol.83, pp.1620-1630, 2002. ,
Allosteric Changes in Protein Structure Computed by a Simple Mechanical Model: Hemoglobin T???R2 Transition, Journal of Molecular Biology, vol.333, issue.1, pp.153-168, 2003. ,
DOI : 10.1016/j.jmb.2003.08.027
Low-frequency normal modes that describe allosteric transitions in biological nanomachines are robust to sequence variations, Proceedings of the National Academy of Sciences, vol.30, issue.2, pp.7664-7669, 2006. ,
DOI : 10.1002/(SICI)1097-0134(19980201)30:2<144::AID-PROT4>3.0.CO;2-N
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1472502
An NMA-guided path planning approach for computing large-amplitude conformational changes in proteins, Proteins: Structure, Function, and Bioinformatics, vol.33, issue.1, pp.131-143, 2008. ,
DOI : 10.1002/prot.21570
Rapid protein-ligand docking using soft modes from molecular dynamics simulations to account for protein deformability: Binding of FK506 to FKBP, Proteins: Structure, Function, and Bioinformatics, vol.1110, issue.4, pp.759-767, 2004. ,
DOI : 10.1002/prot.10637
Refinement of docked protein-ligand and protein-DNA structures using low frequency normal mode amplitude optimization, Nucleic Acids Research, vol.33, issue.14, pp.4496-4506, 2005. ,
DOI : 10.1093/nar/gki730
URL : http://doi.org/10.1093/nar/gki730
Accounting for global protein deformability during protein???protein and protein???ligand docking, Biochimica et Biophysica Acta (BBA) - Proteins and Proteomics, vol.1754, issue.1-2, pp.225-231, 2005. ,
DOI : 10.1016/j.bbapap.2005.07.045
Energy minimization in low-frequency normal modes to efficiently allow for global flexibility during systematic protein-protein docking, Proteins: Structure, Function, and Bioinformatics, vol.15, issue.3, pp.794-809, 2007. ,
DOI : 10.1002/prot.21579
Insights into protein flexibility: The relationship between normal modes and conformational change upon protein-protein docking, Proceedings of the National Academy of Sciences, vol.24, issue.9, pp.10390-10395, 2008. ,
DOI : 10.1093/bioinformatics/btn093
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2475499
SwarmDock and the Use of Normal Modes in Protein-Protein Docking, International Journal of Molecular Sciences, vol.102, issue.10, pp.3623-3648, 2010. ,
DOI : 10.1002/prot.22770
Structure Fluctuations and Conformational Changes in Protein Binding Cui, Q. a Coarse-Grained Normal Mode Approach for Macromolecules: An Efficient Implementation and Application Ca 2+ -ATPase, J. Bioinform . Comput. Biol. Biophys. J, vol.2012, issue.83, pp.1241002-1241028, 2002. ,
Accounting for Large Amplitude Protein Deformation during in Silico Macromolecular Docking, International Journal of Molecular Sciences, vol.38, issue.12, pp.1316-1333, 2011. ,
DOI : 10.3390/ijms12021316
URL : http://doi.org/10.3390/ijms12021316
Prediction of homoprotein and heteroprotein complexes by protein docking and template-based modeling: A CASP-CAPRI experiment, Proteins: Structure, Function, and Bioinformatics, vol.78, issue.9, pp.323-348, 2016. ,
DOI : 10.1002/prot.25007
A load-dependent basis for reduced nonlinear structural dynamics, Computers & Structures, vol.20, issue.1-3, pp.203-210, 1985. ,
DOI : 10.1016/0045-7949(85)90069-0
Normal Modes for Non-Linear Vibratory Systems, Journal of Sound and Vibration, vol.164, issue.1, pp.85-124, 1993. ,
DOI : 10.1006/jsvi.1993.1198
URL : https://deepblue.lib.umich.edu/bitstream/2027.42/30744/1/0000394.pdf
A NEW GALERKIN-BASED APPROACH FOR ACCURATE NON-LINEAR NORMAL MODES THROUGH INVARIANT MANIFOLDS, Journal of Sound and Vibration, vol.249, issue.5, pp.971-993, 2002. ,
DOI : 10.1006/jsvi.2001.3914
Protein normal-mode dynamics: Trypsin inhibitor, crambin, ribonuclease and lysozyme, Journal of Molecular Biology, vol.181, issue.3, pp.423-447, 1985. ,
DOI : 10.1016/0022-2836(85)90230-X
Algorithm for normal mode analysis with general internal coordinates, Journal of Computational Chemistry, vol.107, issue.7, pp.826-841, 2003. ,
DOI : 10.1002/jcc.10247
A New Method for Coarse-Grained Elastic Normal-Mode Analysis, Journal of Chemical Theory and Computation, vol.2, issue.3, pp.464-471, 2006. ,
DOI : 10.1021/ct050307u
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3133770
iMod: multipurpose normal mode analysis in internal coordinates, Bioinformatics, vol.27, issue.20, pp.2843-2850, 2011. ,
DOI : 10.1093/bioinformatics/btr497
Normal Modes As Refinement Parameters for the F-Actin Model, Biophys . J, vol.68, pp.5-12, 1995. ,
Conformational Sampling of Protein Flexibility in Generalized Coordinates: Application to Ligand Docking, Journal of Computational and Theoretical Nanoscience, vol.2, issue.3, pp.354-361, 2005. ,
DOI : 10.1166/jctn.2005.204
Optimized Torsion-Angle Normal Modes Reproduce Conformational Changes More Accurately Than Cartesian Modes, Biophysical Journal, vol.101, issue.12, pp.2966-2969, 2011. ,
DOI : 10.1016/j.bpj.2011.10.054
URL : http://doi.org/10.1016/j.bpj.2011.10.054
Dynamics of Native Globular Proteins in Terms of Dihedral Angles, Journal of the Physical Society of Japan, vol.52, issue.9, pp.3283-3288, 1983. ,
DOI : 10.1143/JPSJ.52.3283
Efficient determination of low-frequency normal modes of large protein structures by cluster-NMA, Journal of Molecular Graphics and Modelling, vol.24, issue.1, pp.46-58, 2005. ,
DOI : 10.1016/j.jmgm.2005.05.002
Multiscale modeling of macromolecular conformational changes combining concepts from rigidity and elastic network theory, Proteins: Structure, Function, and Bioinformatics, vol.84, issue.4, pp.1038-1051, 2006. ,
DOI : 10.1002/prot.20907
Density-cluster NMA: A new protein decomposition technique for coarse-grained normal mode analysis, Proteins: Structure, Function, and Bioinformatics, vol.100, pp.1766-1779, 2012. ,
DOI : 10.1002/prot.24072
Normal mode analysis of proteins: a comparison of rigid cluster modes with C?? coarse graining, Journal of Molecular Graphics and Modelling, vol.22, issue.3, pp.183-193, 2004. ,
DOI : 10.1016/S1093-3263(03)00158-X
Coarse-grained normal mode analysis in structural biology, Current Opinion in Structural Biology, vol.15, issue.5, pp.586-592, 2005. ,
DOI : 10.1016/j.sbi.2005.08.007
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1482533
Dynamics of proteins predicted by molecular dynamics simulations and analytical approaches: Application to ?-amylase inhibitor, Proteins: Structure, Function, and Genetics, vol.7, issue.3, pp.512-524, 2000. ,
DOI : 10.1002/1097-0134(20000815)40:3<512::AID-PROT180>3.0.CO;2-M
Evaluation of Protein Elastic Network Models Based on an Analysis of Collective Motions, Journal of Chemical Theory and Computation, vol.9, issue.12, pp.5618-5628 ,
DOI : 10.1021/ct400399x
Comparing the intrinsic dynamics of multiple protein structures using elastic network models, Biochimica et Biophysica Acta (BBA) - General Subjects, vol.1850, issue.5, pp.911-922, 2015. ,
DOI : 10.1016/j.bbagen.2014.09.021
A comparison of neighbor search algorithms for large rigid molecules, Journal of Computational Chemistry, vol.250, issue.13, pp.2865-2877, 2011. ,
DOI : 10.1002/jcc.21868
URL : https://hal.archives-ouvertes.fr/hal-00748053
EMDataBank Unified Data Resource for 3DEM, Nucleic Acids Res, vol.44, pp.396-403, 2016. ,
Direct Observation of TALE Protein Dynamics Reveals a Two-State Search Mechanism Large Terminase Conformational Change Induced by Connector Binding in Bacteriophage T7, Nat. Commun. 2015 J. Biol. Chem, vol.288, pp.6-55, 2013. ,
Development and Current Status of the CHARMM Force Field for Nucleic Acids, Biopolymers, vol.56, pp.257-265, 2000. ,
How well does a restrained electrostatic potential (RESP) model perform in calculating conformational energies of organic and biological molecules?, Journal of Computational Chemistry, vol.18, issue.12, pp.1049-1074, 2000. ,
DOI : 10.1002/1096-987X(200009)21:12<1049::AID-JCC3>3.0.CO;2-F
MolProbity: All-Atom Structure Validation for Macromolecular Crystallography, Acta Crystallogr., Sect. D: Biol. Crystallogr, vol.66, pp.12-21, 2010. ,
ProDy: Protein Dynamics Inferred from Theory and Experiments, Bioinformatics, vol.27, issue.11, pp.1575-1577, 2011. ,
DOI : 10.1093/bioinformatics/btr168
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3102222
Exploring Large Macromolecular Functional Motions on Clusters of Multicore Processors, J. Comput. Phys, vol.246, pp.275-288, 2013. ,
