Abstract : Efficient algorithms for binary field operations are required in several cryptographic operations such as digital signatures over binary elliptic curves and encryption. The main performance-critical operation in these fields is the multiplication, since most processors do not support instructions to carry out a polynomial multiplication. In this paper we describe a novel software multiplier for performing a polynomial multiplication of two 64-bit binary polynomials based on the VMULL instruction included in the NEON engine supported in many ARM processors. This multiplier is then used as a building block to obtain a fast software multiplication in the binary field $\mathbb{F}_{2^m}$, which is up to 45% faster compared to the best known algorithm. We also illustrate the performance improvement in point multiplication on binary elliptic curves using the new multiplier, improving the performance of standard NIST curves at the 128- and 256-bit levels of security. The impact on the GCM authenticated encryption scheme is also studied, with new speed records. We present timing results of our software implementation on the ARM Cortex-A8, A9 and A15 processors.
https://hal.inria.fr/hal-01506572 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, April 12, 2017 - 10:25:05 AM Last modification on : Friday, August 5, 2022 - 11:52:03 AM Long-term archiving on: : Thursday, July 13, 2017 - 12:39:05 PM
Danilo Câmara, Conrado Gouvêa, Julio López, Ricardo Dahab. Fast Software Polynomial Multiplication on ARM Processors Using the NEON Engine. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.137-154. ⟨hal-01506572⟩
