Fast text searching for regular expressions or automation searching on tries, Journal of ACM 1996, vol.43, issue.6, pp.915-936 ,
DOI : 10.1145/235809.235810
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.2155
Fast planning through planning graph analysis, Artificial Intelligence, vol.90, issue.2, pp.279-298, 1997. ,
New Algorithms for Subset Query, Partial Match, Orthogonal Range Searching, and Related Problems, LNCS, vol.2380, pp.451-462, 2002. ,
DOI : 10.1007/3-540-45465-9_39
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.1049
Combining left and right unlinking for matching a large number of learned rules, AAAI-94, pp.451-458, 1994. ,
Database dependency discovery: a machine learning approach, AI Communications, vol.12, issue.3, pp.139-160, 1999. ,
Rete: A fast algorithm for the many pattern/many object pattern match problem, Artificial Intelligence, vol.19, issue.1, pp.17-37, 1982. ,
DOI : 10.1016/0004-3702(82)90020-0
A performance study of Four Index Structures for Set-Valued Attributes of Low Cardinality, The VLDB Journal -The International Journal on Very Large Data Bases, pp.244-261, 2003. ,
A New Method to Index and Query Sets, IJCAI, 1999. ,
Similarity search in sets and categorical data using the signature tree, Proceedings 19th International Conference on Data Engineering (Cat. No.03CH37405), 2003. ,
DOI : 10.1109/ICDE.2003.1260783
Levelwise search and borders of theories in knowledge discovery, Data Mining and Knowledge Discovery, vol.1, issue.3, pp.241-258, 1997. ,
DOI : 10.1023/A:1009796218281
An Introduction to Information Retrieval, Draft, 2009. ,
Adaptive algorithms for set containment joins, ACM Transactions on Database Systems, vol.28, issue.1, pp.1-38, 2003. ,
DOI : 10.1145/762471.762474
Partial-Match Retrieval Algorithms, SIAM Journal on Computing, vol.5, issue.1, 1976. ,
DOI : 10.1137/0205003
Introduction to Algorithms, 2001. ,
Bottom-up Induction of Functional Dependencies from Relations, Proc. of KDD'93 Workshop: Knowledge Discovery from Databases, pp.174-185, 1993. ,
Efficient subset and superset queries, Local Proceedings and Materials of Doctoral Consortium of the Tenth International Baltic Conference on Databases and Information Systems, 2012. ,
Discovery of multivalued dependencies from relations, Intelligent Data Analysis Journal, Intelligent Data Analysis Journal, vol.4, pp.195-211, 2000. ,
A combination of trie-trees and inverted files for the indexing of set-valued attributes, Proceedings of the 15th ACM international conference on Information and knowledge management , CIKM '06, 2006. ,
DOI : 10.1145/1183614.1183718
Signature-based structures for objects with set-valued attributes, Information Systems, vol.27, issue.2, pp.93-121, 2002. ,
DOI : 10.1016/S0306-4379(01)00047-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.8899
On Supporting Containment Queries in Relational Database Management Systems, ACM SIGMOD, 2001. ,
DOI : 10.1145/375663.375722
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.129.2636
