MPI: A Message-Passing Interface Standard, Tech. rep, 1994. ,
OpenMP: an industry standard API for shared-memory programming, IEEE Computational Science and Engineering, vol.5, issue.1, pp.46-55, 1998. ,
DOI : 10.1109/99.660313
StarPU: A Unified Platform for Task Scheduling on Heterogeneous Multicore Architectures , Concurrency and Computation: Practice and Experience, Special Issue: Euro-Par, pp.187-198, 2009. ,
DOI : 10.1007/978-3-642-03869-3_80
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.220.5547
PaRSEC: A programming paradigm exploiting heterogeneity for enhancing scalability, Computing in Science and Engineering, vol.99 ,
DOI : 10.1109/mcse.2013.98
URL : https://hal.archives-ouvertes.fr/hal-00930217
Three-dimensional aerodynamics with moving bodies applied to solid propellant, 27th Joint Propulsion Conference, 1991. ,
DOI : 10.2514/6.1991-2304
Temporal adaptive Euler/Navier-Stokes algorithm involving unstructured dynamic meshes, AIAA Journal, vol.30, issue.8, pp.30-1980, 1992. ,
DOI : 10.2514/3.11169
Finite element methods for high speed flows, 7th Computational Physics Conference, 1985. ,
DOI : 10.2514/6.1985-1531
Temporal and spatial adaptive algorithm for reacting flows, Communications in Applied Numerical Methods, vol.24, issue.1, pp.97-111, 1988. ,
DOI : 10.1002/cnm.1630040114
An Introduction to Computational Fluid Dynamics: The Finite Volume Method, Pearson Education, 2007. ,
From RANS to DNS: towards a bridging model, in: Direct and Large-Eddy Simulation III, pp.225-236, 1999. ,
An arbitrary lagrangian-eulerian computing method for all flow speeds, Journal of Computational Physics, vol.1474, issue.3, pp.227-253, 1974. ,
DOI : 10.1016/0021-9991(74)90051-5
Two new Chimera methods: application to missile separation, Tiré à part-Office ,
Grid adaptation using chimera composite overlapping meshes, AIAA Journal, vol.32, issue.5, pp.942-949, 1994. ,
DOI : 10.2514/3.12078
Simulation d'interactions aérodynamiques instationnaires autour de plusieurs corps en mouvement relatif, AAAF : Les interactions en aérodynamique, 1998. ,
Extending the OpenMP Tasking Model to Allow Dependent Tasks, Lecture Notes in Computer Science, vol.5004, pp.111-122, 2008. ,
DOI : 10.1007/978-3-540-79561-2_10
URL : http://hdl.handle.net/2117/28390
Legion: Programming distributed heterogeneous architectures with logical regions, 2014. ,
Supermatrix out-of-order scheduling of matrix operations for SMP and multi-core architectures, Proceedings of the nineteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '07, pp.116-125, 2007. ,
DOI : 10.1145/1248377.1248397
Flexible Development of Dense Linear Algebra Algorithms on Massively Parallel Architectures with DPLASMA, 2011 IEEE International Symposium on Parallel and Distributed Processing Workshops and Phd Forum, 2011. ,
DOI : 10.1109/IPDPS.2011.299
Taking Advantage of Hybrid Systems for Sparse Direct Solvers via Task-Based Runtimes, 2014 IEEE International Parallel & Distributed Processing Symposium Workshops, 2014. ,
DOI : 10.1109/IPDPSW.2014.9
URL : https://hal.archives-ouvertes.fr/hal-00925017
Task-Based FMM for Multicore Architectures, SIAM Journal on Scientific Computing, vol.36, issue.1, pp.66-93, 2014. ,
DOI : 10.1137/130915662
URL : https://hal.archives-ouvertes.fr/hal-00807368
Automatic task graph generation techniques, in: System Sciences, Proceedings of the Twenty-Eighth Hawaii International Conference on, pp.113-122, 1995. ,
Optimizing compilers for modern architectures: a dependence-based approach, 2002. ,
Exploiting two-level parallelism by aggregating computing resources in task-based applications over accelerator-based machines, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01502749
Scotch: A software package for static mapping by dual recursive bipartitioning of process and architecture graphs, High-Performance Computing and Networking, pp.493-498, 1996. ,
DOI : 10.1007/3-540-61142-8_588
Composing multiple StarPU applications over heterogeneous machines: a supervised approach, Third International Workshop on Accelerators and Hybrid Exascale Systems, 2013. ,
DOI : 10.1177/1094342014527575
URL : https://hal.archives-ouvertes.fr/hal-00824514
