A Discontinuous Adaptive Sliding-Mode Observer for a Class of Uncertain Nonlinear Systems ⋆ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper the problem of simultaneous state and parameter estimation is studied for a class of uncertain nonlinear systems. A discontinuous adaptive sliding-mode observer is proposed based on a discontinuous nonlinear parameter estimation algorithm. It is shown that such an algorithm provides a rate of convergence faster than exponential. Then, the proposed discontinuous parameter estimation algorithm is included in the structure of a sliding-mode state observer providing an ultimate bound for the full estimation error. Some simulation results illustrate the feasibility of the proposed adaptive sliding-mode observer.
IFAC17_0580_FIa.pdf (1.32 Mo) Télécharger le fichier
hal-01508771 , version 1 (14-04-2017)
  • HAL Id : hal-01508771 , version 1
Hector Ríos, Denis Efimov, Wilfrid Perruquetti. A Discontinuous Adaptive Sliding-Mode Observer for a Class of Uncertain Nonlinear Systems ⋆. Proc. 20th IFAC WC 2017, Jul 2017, Toulouse, France. ⟨hal-01508771⟩
430 Consultations
216 Téléchargements
