On design of interval observers for parabolic PDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of state estimation for heat non-homogeneous equations under distributed in space measurements is considered. An interval observer is designed, described by Partial Differential Equations (PDEs), for uncertain distributed parameter systems without application of finite-element approximations. Conditions of boundedness of solutions of interval observer with non-zero boundary conditions and measurement noise are proposed. The results are illustrated by numerical experiments with an academic example.
IFAC17_1615_FIa.pdf (1.5 Mo) Télécharger le fichier
hal-01508773 , version 1 (14-04-2017)
  • HAL Id : hal-01508773 , version 1
Tatiana Kharkovskaia, Denis Efimov, Emilia Fridman, Andrey Polyakov, Jean-Pierre Richard. On design of interval observers for parabolic PDEs. Proc. 20th IFAC WC 2017, Jul 2017, Toulouse, France. ⟨hal-01508773⟩
236 Consultations
251 Téléchargements
