Observer analysis and synthesis for Lipschitz nonlinear systems under discrete time-varying measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Observer synthesis for nonlinear Lipschitz systems with time-varying sampling is studied. To establish the exponential convergence of the observer, in this paper, we model the impact of the sampling uncertainty by a reset integrator. First, generic conditions for stability of a sampled data system are recalled. Second it is shown how to derive tractable numerical conditions to analyze the robustness of a continuous-time Luenberger observer when the sampling is discrete and time-varying. Then it is demonstrated that this emulation approach can be passed over allowing for the direct computation of an observer gain. Simulations and comparisons with related articles show the efficiency of the proposed methodology.
IFAC17_2175_FI.pdf (304.24 Ko) Télécharger le fichier
hal-01508776 , version 1 (14-04-2017)
  • HAL Id : hal-01508776 , version 1
Etienne Lucien, Hetel Laurentiu, Denis Efimov, Petreczky Mihaly. Observer analysis and synthesis for Lipschitz nonlinear systems under discrete time-varying measurements. Proc. 20th IFAC WC 2017, Jul 2017, Toulouse, France. ⟨hal-01508776⟩
349 Consultations
242 Téléchargements
