Controllability of the Schrödinger equation via intersection of eigenvalues, Proceedings of the 44th IEEE Conference on Decision and Control, pp.1080-1085, 2005. ,
Control theory from the geometric viewpoint, of Encyclopaedia of Mathematical Sciences Control Theory and Optimization, II, 2004. ,
DOI : 10.1007/978-3-662-06404-7
Controllability for Distributed Bilinear Systems, SIAM Journal on Control and Optimization, vol.20, issue.4, pp.575-597, 1982. ,
DOI : 10.1137/0320042
URL : http://authors.library.caltech.edu/4635/1/BALsiamjco82.pdf
Controllability of a quantum particle in a moving potential well, Journal of Functional Analysis, vol.232, issue.2, pp.328-389, 2006. ,
DOI : 10.1016/j.jfa.2005.03.021
URL : https://hal.archives-ouvertes.fr/hal-00825517
Local controllability of 1D linear and nonlinear Schr??dinger equations with bilinear control, Journal de Math??matiques Pures et Appliqu??es, vol.94, issue.5, pp.520-554, 2010. ,
DOI : 10.1016/j.matpur.2010.04.001
Quantum control of infinite-dimensional many-body systems, Physical Review A, vol.89, issue.3, p.32309, 2014. ,
DOI : 10.1103/PhysRevA.89.032309
Finite Controllability of Infinite-Dimensional Quantum Systems, IEEE Transactions on Automatic Control, vol.55, issue.8, pp.551797-1805, 2010. ,
DOI : 10.1109/TAC.2010.2044273
URL : http://arxiv.org/abs/quant-ph/0608075
A weak spectral condition for the controllability of the bilinear schrödinger equation with application to the control of a rotating planar molecule, Communications in Mathematical Physics, issue.2, pp.311423-455, 2012. ,
Multi-input Schr??dinger equation: Controllability, tracking, and application to the quantum angular momentum, Journal of Differential Equations, vol.256, issue.11, pp.3524-3551, 2014. ,
DOI : 10.1016/j.jde.2014.02.004
URL : http://arxiv.org/abs/1302.4173
Adiabatic Control of the Schr??dinger Equation via Conical Intersections of the Eigenvalues, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.1970-1983, 2012. ,
DOI : 10.1109/TAC.2012.2195862
Regular propagators of bilinear quantum systems, 2016. ,
Periodic excitations of bilinear quantum systems, Automatica, vol.48, issue.9, pp.2040-2046, 2012. ,
DOI : 10.1016/j.automatica.2012.03.031
URL : https://hal.archives-ouvertes.fr/hal-00594895
Controllability of the discrete-spectrum Schr??dinger equation driven by an external field, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.1, pp.329-349, 2009. ,
DOI : 10.1016/j.anihpc.2008.05.001
On subsemigroups of semisimple Lie groups, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.13, issue.1, pp.117-133, 1996. ,
DOI : 10.1016/S0294-1449(16)30099-3
Controlabilit?? des Syst??mes Bilin??aires, SIAM Journal on Control and Optimization, vol.20, issue.3, pp.377-384, 1982. ,
DOI : 10.1137/0320029
Control systems on semi-simple Lie groups and their homogeneous spaces, Annales de l???institut Fourier, vol.31, issue.4, pp.151-179, 1981. ,
DOI : 10.5802/aif.853
URL : http://archive.numdam.org/article/AIF_1981__31_4_151_0.pdf
Control systems on Lie groups, Journal of Differential Equations, vol.12, issue.2, pp.313-329, 1972. ,
DOI : 10.1016/0022-0396(72)90035-6
URL : http://doi.org/10.1016/0022-0396(72)90035-6
Controlling several atoms in a cavity, New Journal of Physics, vol.16, issue.6, p.65010, 2014. ,
DOI : 10.1088/1367-2630/16/6/065010
Lyapunov control of a quantum particle in a decaying potential, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.5, pp.1743-1765, 2009. ,
DOI : 10.1016/j.anihpc.2008.09.006
URL : https://hal.archives-ouvertes.fr/hal-00793568
Simultaneous global exact controllability of an arbitrary number of 1d bilinear Schr??dinger equations, Journal de Math??matiques Pures et Appliqu??es, vol.103, issue.1, pp.228-254, 2015. ,
DOI : 10.1016/j.matpur.2014.04.002
Growth of Sobolev Norms and Controllability of the Schr??dinger Equation, Communications in Mathematical Physics, vol.33, issue.12, pp.371-387, 2009. ,
DOI : 10.1007/s00220-009-0842-0
Global approximate controllability for Schr??dinger equation in higher Sobolev norms and applications, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.27, issue.3, pp.901-915, 2010. ,
DOI : 10.1016/j.anihpc.2010.01.004
Global exact controllability in infinite time of Schr??dinger equation, Journal de Math??matiques Pures et Appliqu??es, vol.97, issue.4, pp.295-317, 2012. ,
DOI : 10.1016/j.matpur.2011.11.005
Approximate controllability of the two trapped ions system, Quantum Information Processing, vol.75, issue.11, pp.2397-2418, 2015. ,
DOI : 10.1007/s11128-015-0991-3
URL : https://hal.archives-ouvertes.fr/hal-01092509
II: Fourier Analysis, Self-Adjointness, 1975. ,
Some properties of vector field systems that are not altered by small perturbations, Journal of Differential Equations, vol.20, issue.2, pp.292-315, 1976. ,
DOI : 10.1016/0022-0396(76)90109-1
On the controllability of bilinear quantum systems, Mathematical models and methods for ab initio Quantum Chemistry, 2000. ,
DOI : 10.1007/978-3-642-57237-1_4
URL : https://hal.archives-ouvertes.fr/hal-00536518
