Audvert: Using Spatial Audio to Gain a Sense of Place - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Liam Betsworth
  • Fonction : Auteur
  • PersonId : 1006518
Nitendra Rajput
  • Fonction : Auteur
  • PersonId : 1006519
Saurabh Srivastava
  • Fonction : Auteur
  • PersonId : 1006520
Matt Jones
  • Fonction : Auteur
  • PersonId : 1006521
We introduce Audvert – a system that facilitates serendipitous discovery and navigation through spatial audio; used to navigate and discover points of interest in large, unfamiliar indoor environments. Our main aim was to create a lightweight spatial audio display that can convey a sense of a place without complex point and select interactions. We conducted a preliminary study comparing two audio types to see which best suited sound localization and a study of Audvert used in a real world scenario. Our findings suggest that long continuous audio performs better than short intermittent audio for sound localisation. We also discover a change in behaviour when using the system, with a large percentage of users wanting to visit newly discovered shops after using the system. We discuss the findings and draw research conclusions.
978-3-642-40498-6_35_Chapter.pdf (218.8 Ko) Télécharger le fichier
hal-01510524 , version 1 (19-04-2017)
Paternité
Liam Betsworth, Nitendra Rajput, Saurabh Srivastava, Matt Jones. Audvert: Using Spatial Audio to Gain a Sense of Place. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.455-462, ⟨10.1007/978-3-642-40498-6_35⟩. ⟨hal-01510524⟩
57 Consultations
170 Téléchargements
