SecureStreams: A Reactive Middleware Framework for Secure Data Stream Processing
Abstract : The growing adoption of distributed data processing frame-works in a wide diversity of application domains challenges end-to-end integration of properties like security, in particular when considering deployments in the context of large-scale clusters or multi-tenant Cloud infrastructures. This paper therefore introduces SecureStreams, a reactive middleware framework to deploy and process securestreams at scale. Its design combines the high-level reactive data flow programming paradigm with low-level Intel's software guard extensions (SGX) in order to guarantee privacy and integrity of the processed data. The experimental results of SecureStreams are promising: while o ffering a fluent scripting language based on Lua, our middleware delivers high processing throughput, thus enabling developers to implement secure processing pipelines in just few lines of code.
Type de document :
Communication dans un congrès
Mani Chandy; Boris Koldehofe. DEBS'17 - The 11th ACM International Conference on Distributed and Event-Based Systems, Jun 2017, Barcelona, Spain. ACM; ACM Press, pp.124-133, Proceedings of the 11th ACM International Conference on Distributed and Event-Based Systems. 〈http://www.debs2017.org〉. 〈10.1145/3093742.3093927〉
Liste complète des métadonnées
https://hal.inria.fr/hal-01510699
Contributeur : Romain Rouvoy <>
Soumis le : mercredi 20 février 2019 - 20:42:52
Dernière modification le : vendredi 22 mars 2019 - 01:36:48
Fichier
paper.pdf
Fichiers produits par l'(les) auteur(s)
Citation
Aurélien Havet, Rafael Pires, Pascal Felber, Marcelo Pasin, Romain Rouvoy, et al.. SecureStreams: A Reactive Middleware Framework for Secure Data Stream Processing. Mani Chandy; Boris Koldehofe. DEBS'17 - The 11th ACM International Conference on Distributed and Event-Based Systems, Jun 2017, Barcelona, Spain. ACM; ACM Press, pp.124-133, Proceedings of the 11th ACM International Conference on Distributed and Event-Based Systems. 〈http://www.debs2017.org〉. 〈10.1145/3093742.3093927〉. 〈hal-01510699v2〉
Métriques
Consultations de la notice
41
Téléchargements de fichiers
74
