SecureStreams: A Reactive Middleware Framework for Secure Data Stream Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The growing adoption of distributed data processing frame-works in a wide diversity of application domains challenges end-to-end integration of properties like security, in particular when considering deployments in the context of large-scale clusters or multi-tenant Cloud infrastructures. This paper therefore introduces SecureStreams, a reactive middleware framework to deploy and process securestreams at scale. Its design combines the high-level reactive data flow programming paradigm with low-level Intel's software guard extensions (SGX) in order to guarantee privacy and integrity of the processed data. The experimental results of SecureStreams are promising: while o ffering a fluent scripting language based on Lua, our middleware delivers high processing throughput, thus enabling developers to implement secure processing pipelines in just few lines of code.
paper.pdf (509.14 Ko) Télécharger le fichier
hal-01510699 , version 1 (20-11-2017)
hal-01510699 , version 2 (20-02-2019)
Aurélien Havet, Rafael Pires, Pascal Felber, Marcelo Pasin, Romain Rouvoy, et al.. SecureStreams: A Reactive Middleware Framework for Secure Data Stream Processing. DEBS'17 - The 11th ACM International Conference on Distributed and Event-Based Systems, Marta Patiño, Jun 2017, Barcelona, Spain. pp.124-133, ⟨10.1145/3093742.3093927⟩. ⟨hal-01510699v2⟩
2999 Consultations
555 Téléchargements
