A tensorial-based Mesh Adaptation for a Poisson problem
This paper discusses anisotropic mesh adaptation, addressing
either a local interpolation error, or the error on a functional,
or the norm of the approximation error, the two last options
using an adjoint state. This is explained with a Poisson model
problem. We focus on metric-based mesh adaptation using a
priori errors. Continuous metric-based methods were developed
for this purpose. They propose a continuous statement of the
mesh optimisation problem, which need to be then discretised
and solved numerically. Tensorial metric-based methods produce
directly a discrete optimal metric for interpolation error
equirepartition. The novelty of the present paper is to extend
the tensorial discrete method to addressing (1) L 1 errors and
(2) adjoint-based analyses, two functionalities already available
with continuous metric. A first interest is to be able to compare
tensorial and continuous methods when they are applied to the
reduction of approximation errors. Second, an interesting feature
of the new formulation is a potentially sharper analysis of the
approximation error. Indeed, the resulting optimal metric has a
different anisotropic component. The novel formulation is then
compared with the continuous formulation for a few test cases
involving high-gradient layers and gradient discontinuities.
