Convolutional neural network architecture for geometric matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of determining correspondences between two images in agreement with a geometric model such as an affine or thin-plate spline transformation, and estimating its parameters. The contributions of this work are threefold. First, we propose a convolutional neural network architecture for geometric matching. The architecture is based on three main components that mimic the standard steps of feature extraction, matching and simultaneous in-lier detection and model parameter estimation, while being trainable end-to-end. Second, we demonstrate that the network parameters can be trained from synthetically generated imagery without the need for manual annotation and that our matching layer significantly increases generalization capabilities to never seen before images. Finally, we show that the same model can perform both instance-level and category-level matching giving state-of-the-art results on the challenging Proposal Flow dataset.
cnngeometric_HALv1.pdf (8.74 Mo) Télécharger le fichier
hal-01513001 , version 1 (24-04-2017)
Ignacio Rocco, Relja Arandjelovic, Josef Sivic. Convolutional neural network architecture for geometric matching. CVPR 2017 - IEEE Conference on Computer Vision and Pattern Recognition , Jul 2017, Honolulu, United States. ⟨hal-01513001⟩
344 Consultations
812 Téléchargements
