Abstract : To support the digital evolution within Social Sciences and Humanities research, it is necessary to stabilize knowledge on standards and research good practices. The goal of the Standardization Survival Kit (SSK), developed within the PARTHENOS project, is to accompany researchers along this route, giving access to standards and best practices in a meaningful way, by the mediation of research scenarios. A research scenario is a (digital) workflow practiced by researchers, that can be repeatedly applied to a task that will help to gain material or insights in view of a research question. These scenarios are at the core of the SSK, as they embed resources with contextual information and relevant examples on standardized processes and methods in a research context. The SSK is an open tool where users are able to publish new scenarios or adapt existing ones. These scenarios can be seen as a living memory of what should be the best research practices in a given community, made accessible and reusable for other researchers.
