, The TaDIRAH objects vocabulary contains 36 types of research objects, including the most commonly used by Arts and Humanities scholars (note that this list is open, new terms can be added to it). heritage and museology ? Musicology and performing arts
, The WAR file is generated at target/ssk_services.war (assuming the Gradle artifactId is ssk_services)
, To have our WAR file deployed and running in Tomcat, we need to complete the following steps: 1. and unpackage it into a tomcat folder 2. Copy our WAR file from target/ssk_services.war to the tomcat/webapps/ folder 3. From a terminal navigate to tomcat/bin folder and execute catalina.bat run (on Windows) and catalina
, This is how the SSK Back-End has been deployed on the D4Science infrastructure, although Elasticsearch and the Tomcat server have been configured by the platform engineers
, Build and deploy the Front-end of the SSK which is an Angular based application, requires Angular CLI to be installed on your computer. The steps to follow are: 1. To build angular applications, execute the ng build command
, Copy everything within the output folder (dist/ by default) to a folder on the server
, Configure the server to redirect requests for missing files to index.html Source: Angular deployment
Text Encoding for Interchange: A New Consortium. Ariadne(24), 2000. ,
The Onboarding Effect: Leveraging User Engagement and Retention in Crowdsourcing Platforms, pp.263-267, 2017. ,
Twenty Titles for the Writer, College Composition and Communication, vol.43, issue.4, pp.516-519, 1992. ,
The SSK Data Model (TEI)-SSK Documentation, 2018. ,
, Report on Standardization, 2017.
, Standardization Survival Kit (Draft, 2016.
, A Brief Report on the Usability Test for the Standardization Survival Kit (SSK). Other. Inria Paris, 2018.
