One-to-One Disjoint Path Covers in DCell - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
DCell has been proposed for one of the most important data center networks as a server centric data center network structure. DCell can support millions of servers with outstanding network capacity and provide good fault tolerance by only using commodity switches. In this paper, we prove that there exist r vertex disjoint paths {Pi | 1 ≤ i ≤ r} between any two distinct vertices u and v of DCellk (k ≥ 0) where r = n + k − 1 and n is the vertex number of DCell0. The result is optimal because of any vertex in DCellk has r neighbors with r = n + k − 1.
978-3-642-40820-5_6_Chapter.pdf (569.84 Ko) Télécharger le fichier
hal-01513760 , version 1 (25-04-2017)
Paternité
Xi Wang, Jianxi Fan, Baolei Cheng, Wenjun Liu, Yan Wang. One-to-One Disjoint Path Covers in DCell. 10th International Conference on Network and Parallel Computing (NPC), Sep 2013, Guiyang, China. pp.61-70, ⟨10.1007/978-3-642-40820-5_6⟩. ⟨hal-01513760⟩
42 Consultations
83 Téléchargements
