Streamwise vortex structure in plane mixing layers, Journal of Fluid Mechanics, vol.14, issue.-1, pp.499-525, 1986. ,
DOI : 10.1017/S0022112084000781__S0022112084000781
On density effects and large structure in turbulent mixing layers, Journal of Fluid Mechanics, vol.87, issue.04, pp.775-816, 1974. ,
DOI : 10.1017/S002211207400190X
Closed-Loop Turbulence Control: Progress and Challenges, Applied Mechanics Reviews, vol.67, issue.5, pp.50801-050801, 2015. ,
DOI : 10.1115/1.4031175
Turbulent mixing and entrainment in a stratified??horizontal plane shear layer: joint velocity???temperature analysis of experimental??data, Journal of Fluid Mechanics, vol.26, pp.542-579, 2016. ,
DOI : 10.1088/0957-0233/11/9/306
URL : https://hal.archives-ouvertes.fr/hal-01409794
The mixing layer: deterministic models of a turbulent flow. Part 2. The origin of the three-dimensional motion, Journal of Fluid Mechanics, vol.109, issue.-1, pp.67-95, 1984. ,
DOI : 10.1063/1.862881
Feed-forward control of a perturbed backward-facing step flow, Journal of Fluid Mechanics, vol.142, pp.181-196, 2014. ,
DOI : 10.1017/S0022112096003941
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.28, issue.4, pp.369-393, 2010. ,
DOI : 10.1007/s00348-009-0778-3
URL : https://hal.archives-ouvertes.fr/hal-00456162
Double-frequency forcing on spatially growing mixing layers, Journal of Fluid Mechanics, vol.16, issue.-1, pp.553-581, 1992. ,
DOI : 10.1017/S0022112067002538
A systems theory approach to the feedback stabilization of infinitesimal and finite-amplitude disturbances in plane Poiseuille flow, Journal of Fluid Mechanics, vol.24, pp.157-184, 1997. ,
DOI : 10.1017/S0022112087000892
Finite Dimensional Optimal Control of Poiseuille Flow, Journal of Guidance, Control, and Dynamics, vol.22, issue.2, pp.340-348, 1999. ,
DOI : 10.2514/2.4383
An Efficient CFD-based PID Control of Free Shear Layer Flow, 43rd Fluid Dynamics Conference, 2013. ,
DOI : 10.2514/6.2013-2986
First Principles Based PID Control of Mixing Layer: Role of Inflow Perturbation Spectrum, 7th AIAA Flow Control Conference, 2014. ,
DOI : 10.2514/6.2014-2222
A Linear Systems Approach to Flow Control, Annual Review of Fluid Mechanics, vol.39, issue.1, pp.383-417, 2007. ,
DOI : 10.1146/annurev.fluid.39.050905.110153
High-order compact schemes for incompressible flows: A simple and efficient method with quasi-spectral accuracy, Journal of Computational Physics, vol.228, issue.16, pp.5989-6015, 2009. ,
DOI : 10.1016/j.jcp.2009.05.010
URL : https://hal.archives-ouvertes.fr/hal-00459942
Incompact3d: A powerful tool to tackle turbulence problems with up to O(105) computational cores, International Journal for Numerical Methods in Fluids, vol.22, issue.10, pp.1735-1757, 2011. ,
DOI : 10.1002/fld.2480
Control of Plane Poiseuille Flow: A theoretical and Computationnal Investigation, 2006. ,
On spatially growing disturbances in an inviscid shear layer, Journal of Fluid Mechanics, vol.10, issue.03, pp.521-544, 1965. ,
DOI : 10.1007/BF00537616
Influence of the velocity ratio on the spatial instability of mixing layers, Physics of Fluids, vol.25, issue.7, pp.1137-1143, 1982. ,
DOI : 10.1063/1.863880
On the effect of initial conditions on the two dimensional turbulent mixing layer, Lecture Notes in Physics, vol.75, pp.48-64, 1978. ,
DOI : 10.1007/3-540-08765-6_5
Mixing layer manipulation experiment . Flow, Turbulence and Combustion, pp.155-173, 2015. ,
Stability and transition in shear flows, 2001. ,
DOI : 10.1007/978-1-4613-0185-1
Experimental study of thermal mixing layer using variable temperature hotwire anemometry, Experiments in Fluids, vol.54, issue.10, pp.1-19, 2013. ,
Fluid Flow Control: A Vision-Based Approach, International Journal of Flow Control, vol.3, issue.2-3, pp.133-169, 2011. ,
DOI : 10.1260/1756-8250.3.2-3.133
URL : https://hal.archives-ouvertes.fr/hal-00701080
The response of a mixing layer formed between parallel streams to a concomitant excitation at two frequencies, J. Fluid Mech, vol.441, pp.139-168, 2001. ,
