Journal articles
Example-Based Expressive Animation of 2D Rigid Bodies
Marek Dvorožňák 1 Pierre Bénard 2 Pascal Barla 2 Oliver Wang 3 Daniel Sýkora 1
2 MANAO - Melting the frontiers between Light, Shape and Matter
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, LP2N - Laboratoire Photonique, Numérique et Nanosciences
Abstract : We present a novel approach to facilitate the creation of stylized 2D rigid body animations. Our approach can handle multiple rigid objects following complex physically-simulated trajectories with collisions, while retaining a unique artistic style directly specified by the user. Starting with an existing target animation (e.g., produced by a physical simulation engine) an artist interactively draws over a sparse set of frames, and the desired appearance and motion stylization is automatically propagated to the rest of the sequence. The stylization process may also be performed in an off-line batch process from a small set of drawn sequences. To achieve these goals, we combine parametric deformation synthesis that generalizes and reuses hand-drawn exemplars, with non-parametric techniques that enhance the hand-drawn appearance of the synthesized sequence. We demonstrate the potential of our method on various complex rigid body animations which are created with an expressive hand-drawn look using notably less manual interventions as compared to traditional techniques.
Document type :
Journal articles
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-01514619
Contributor : Pierre Bénard Connect in order to contact the contributor
Submitted on : Wednesday, April 26, 2017 - 2:28:37 PM
Last modification on : Friday, December 3, 2021 - 3:38:09 PM
Long-term archiving on: : Thursday, July 27, 2017 - 12:56:32 PM
Identifiers
Collections
Citation
Marek Dvorožňák, Pierre Bénard, Pascal Barla, Oliver Wang, Daniel Sýkora. Example-Based Expressive Animation of 2D Rigid Bodies. ACM Transactions on Graphics, Association for Computing Machinery, 2017, 36 (4), pp.10. ⟨10.1145/3072959.3073611⟩. ⟨hal-01514619⟩
Share
Metrics
Record views
4480
Files downloads
4480
