Conference papers
Fast algorithm for border bases of Artinian Gorenstein algebras
Bernard Mourrain 1
1 AROMATH - AlgebRe, geOmetrie, Modelisation et AlgoriTHmes
CRISAM - Inria Sophia Antipolis - Méditerranée , NKUA - National and Kapodistrian University of Athens
Abstract : Given a multi-index sequence $σ$, we present a new efficient algorithm to compute generators of the linear recurrence relations between the terms of $σ$. We transform this problem into an algebraic one, by identifying multi-index sequences, multivariate formal power series and linear functionals on the ring of multivariate polynomials. In this setting, the recurrence relations are the elements of the kernel $I_σ$ of the Hankel operator $H_σ$ associated to $σ$. We describe the correspondence between multi-index sequences with a Hankel operator of finite rank and Artinian Gorenstein Algebras. We show how the algebraic structure of the Artinian Gorenstein algebra $A_σ$ associated to the sequence $σ$ yields the structure of the terms $σ_α$ for all $α ∈ N^n$. This structure is explicitly given by a border basis of $A_σ$, which is presented as a quotient of the polynomial ring $K[x_1 ,. .. , x_n$] by the kernel $I_σ$ of the Hankel operator $H_σ$. The algorithm provides generators of $I_σ$ constituting a border basis, pairwise orthogonal bases of $A_σ$ and the tables of multiplication by the variables in these bases. It is an extension of Berlekamp-Massey-Sakata (BMS) algorithm, with improved complexity bounds. We present applications of the method to different problems such as the decomposition of functions into weighted sums of exponential functions, sparse interpolation, fast decoding of algebraic codes, computing the vanishing ideal of points, and tensor decomposition. Some benchmarks illustrate the practical behavior of the algorithm.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01515366
Contributor : Bernard Mourrain Connect in order to contact the contributor
Submitted on : Wednesday, May 3, 2017 - 11:37:59 AM
Last modification on : Thursday, November 26, 2020 - 3:50:03 PM
Long-term archiving on: : Friday, August 4, 2017 - 12:13:52 PM
paper-hal.pdf
Identifiers
Collections
Citation
Bernard Mourrain. Fast algorithm for border bases of Artinian Gorenstein algebras. ISSAC'17 -- International Symposium on Symbolic and Algebraic Computation, Jul 2017, Kaiserslautern, Germany. pp.333--340, ⟨10.1145/3087604.3087632⟩. ⟨hal-01515366v1⟩
Share
Metrics
Record views
503
Files downloads
419
