A QoS-Aware Hyper-graph Based Method of Semantic Service Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cui Lizhen
  • Fonction : Auteur
  • PersonId : 1007142
Xu Meng
  • Fonction : Auteur
Semantic service composition is an important issue in web service based systems. It is about how to build a new, reusable and value-added service by combining existing semantic web services. In this paper we propose a new hyper-graph based method supporting semantic service composition, which model the service composition problem as a hyper-graph. Then the hyper-graph based service composition algorithm has been implemented and evaluated. The evaluation results have shown that the method can effectively reduce the composition time and has good robustness, especially in the case of large number of web services and concepts.
978-3-642-33068-1_9_Chapter.pdf (396.98 Ko) Télécharger le fichier
hal-01515737 , version 1 (28-04-2017)
Paternité
Cui Lizhen, Xu Meng. A QoS-Aware Hyper-graph Based Method of Semantic Service Composition. 4th International Working Conference on Enterprise Interoperability (IWEI), Sep 2012, Harbin, China. pp.81-91, ⟨10.1007/978-3-642-33068-1_9⟩. ⟨hal-01515737⟩
49 Consultations
65 Téléchargements
