Yuliang Shi, and Lizhen Cui Session 3: Model Manipulation and Ontology Building A QoS-Aware Hyper-graph Based Method of Semantic Service Composition, p.81 ,
Information Customization and Interoperability in Food Chains, p.92 ,
Value-Oriented Iterative Service Modeling Process, p.104 ,
Model-Driven Service Engineering in Enterprise Ecosystems Principles of Servitization and Definition of an Architecture for Model Driven Service System Engineering 117 Yves Ducq, David Chen, and Thècle Alix Control-Flow Pattern Based Transformation from UML Activity Diagram to YAWL, 129 Zhaogang Han ,
Goncalves An Approach for Validating Semantic Consistency of Model Transformation Based on Pattern, p.161 ,
172 Carlos Coutinho, Adina Cretan, and Ricardo Jardim-Goncalves Short Papers A Hypergraph Partition Based Approach to Dynamic Deployment for Service-Oriented Multi-tenant, SaaS Applications, p.185 ,
Shijun Liu, and Xiangxu Meng Table of Contents XIII Service-Oriented Digital Identity-Related Privacy Interoperability: Implementation Framework of Privacy-as-a-Set-of-Services (PaaSS) ,
Hélie Research on Semantic Interoperability for Business Collaboration, p.201 ,
