Manufacturing Software Interoperability Services Which ISO 16100 Brings about - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michiko Matsuda
  • Fonction : Auteur
  • PersonId : 1003725
ISO 16100 series provides a standardized methodology for the interoperability of manufacturing software using capability profiling. The method for describing software capability as Capability Profile and the way for exchanging software capability as information through Capability Profile are provided by ISO 16100. By using these two fruits from ISO 16100, two new interoperability services are proposed. One is a new manufacturing application developing method using the manufacturing software capability catalogue as cloud service. The other is a new manufacturing system configuration method by plug-and-play of manufacturing software. Finally, further enhancement of interoperability services are discussed.
978-3-642-33068-1_7_Chapter.pdf (267.63 Ko) Télécharger le fichier
hal-01515743 , version 1 (28-04-2017)
Paternité
Michiko Matsuda. Manufacturing Software Interoperability Services Which ISO 16100 Brings about. 4th International Working Conference on Enterprise Interoperability (IWEI), Sep 2012, Harbin, China. pp.60-70, ⟨10.1007/978-3-642-33068-1_7⟩. ⟨hal-01515743⟩
137 Consultations
89 Téléchargements
