On the Proof Theory of Indexed Nested Sequents for Classical and Intuitionistic Modal Logics - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2017
(1) , (1)
1
Fitting's indexed nested sequents can be used to give deductive systems to modal logics which cannot be captured by pure nested sequents. In this paper we show how the standard cut-elimination procedure for nested sequents can be extended to indexed nested sequents, and we discuss how indexed nested sequents can be used for intuitionistic modal logics.
RR-9061.pdf (812.68 Ko) Télécharger le fichier
Dates and versions
hal-01515797 , version 1 (28-04-2017)
Identifiers
  • HAL Id : hal-01515797 , version 1
Cite
Sonia Marin, Lutz Strassburger. On the Proof Theory of Indexed Nested Sequents for Classical and Intuitionistic Modal Logics. [Research Report] RR-9061, Inria. 2017. ⟨hal-01515797⟩
222 View
71 Download
Share
