On the Proof Theory of Indexed Nested Sequents for Classical and Intuitionistic Modal Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Fitting's indexed nested sequents can be used to give deductive systems to modal logics which cannot be captured by pure nested sequents. In this paper we show how the standard cut-elimination procedure for nested sequents can be extended to indexed nested sequents, and we discuss how indexed nested sequents can be used for intuitionistic modal logics.
RR-9061.pdf (812.68 Ko) Télécharger le fichier
hal-01515797 , version 1 (28-04-2017)
  • HAL Id : hal-01515797 , version 1
Sonia Marin, Lutz Strassburger. On the Proof Theory of Indexed Nested Sequents for Classical and Intuitionistic Modal Logics. [Research Report] RR-9061, Inria. 2017. ⟨hal-01515797⟩
259 Consultations
78 Téléchargements
