A Two-Scale Microfacet Reflectance Model Combining Reflection and Diffraction
Adequate reflectance models are essential for the production of photorealistic images. Microfacet reflectance models predict the appearance of a material at the macroscopic level based on microscopic surface details. They provide a good match with measured reflectance in some cases, but not always. This discrepancy between the behavior predicted by microfacet models and the observed behavior has puzzled researchers for a long time. In this paper, we show that diffraction effects in the micro-geometry provide a plausible explanation. We describe a two-scale reflectance model, separating between geometry details much larger than wavelength and those of size comparable to wavelength. The former model results in the standard Cook-Torrance model. The latter model is responsible for diffraction effects. Diffraction effects at the smaller scale are convolved by the micro-geometry normal distribution. The resulting two-scale model provides a very good approximation to measured reflectances.
paper.pdf (15.72 Mo)
Télécharger le fichier
siggraphTalk.key.zip (37.7 Mo)
siggraphTalk.pdf (27.62 Mo)
siggraphTalk_comments.pdf (32.14 Mo)
sourceCode.zip (10.01 Mo)
supplemental_Siggraph_2017_V2.pdf (442.71 Mo)
Origin : Publisher files allowed on an open archive
Format : Figure, Image
